First post, by Der Kuenringer
Hello,
I need some help finding a unicorn.
I'm looking for a micro-ATX/mATX motherboard that has an ISA slot AND an SB-link header.
I'm planning to use an MPU-401 interface card in the ISA slot, so I'm not sure if that is an ISA DMA-dependent device? In case it is, the boards also needs a working ISA DMA.
The alternative would be a mATX board with 2 ISA slots and ISA DMA. (So far I've only found a Socket 1 board with those specifications)
Further qualifications:
1., The board needs to have an AGP slot.
2., It needs to be Socket 370 or Socket 478. In case of a board with 2 ISA slots, Socket A is fine as well.
Does such a board exist?
