First post, by 386SX
for the usual 'older cpu vs old cpu' question, today I ask your opinion into this fight, the Pentium 4 661 3,6Ghz (Cedar Mill) vs the Pentium Dual E2160 1,8Ghz (Allendale).
Thank 😀
Reply 1 of 7, by Baoran
E2160 is about 2 times faster than the P4
Reply 3 of 7, by agent_x007
If you want perf. get a E2160.
Reply 4 of 7, by 386SX
Thank you. It's incredible how well still can run these low end old cpu. I was thinking to test the jump from the 3,4 prescott to the 661 cedar mill to the e2160 to the e8600. 😀
Reply 5 of 7, by 386SX
Another question I don't understand... why the P4 Prescot 3,4Ghz on 478 in the FPU Raytracing benchmark of linux give somthing like 50 points and the P4 3,6Ghz Cedar Mill on 775 gives like 9 points (lower = better)??? Was there some changes in the FPU?
Reply 6 of 7, by diopside
Cedar Mill is just a die-shrink of Prescott-2M. There are no architecture changes. And 50 is much too high. My Prescott Celeron-D at 3.2 GHz manages about 23.7.
Here are the full benchmarks of that Celeron:
Blowfish 15.7
Cryptohash 113.65
Fibonacci 4.53
N-Queens 9.44
FFT 9.55
Raytracing 23.69
Reply 7 of 7, by 386SX
diopside wrote:
Cedar Mill is just a die-shrink of Prescott-2M. There are no architecture changes. And 50 is much too high. My Prescott Celeron- […]
Blowfish 15.7
Cryptohash 113.65
Fibonacci 4.53
N-Queens 9.44
FFT 9.55
Raytracing 23.69
Also the Raspberry Pi 3 B+ have better values on FPU, need to test it again something was probably wrong.
