First post, by D131
I have a few problems with DOSbox memory sizes. Some games that I would like to play with DOSbox are snail-like slow, so I thought that adding some memory -within- DOSbox could speed things up. My guess is that I should add conventional OR extended OR expanded memory. The question is how do I do that? I searched thru the FAQ etc and found nothing (or I'm just blind)
I run a Pentium 4 (3ghz), 1gb ram, with Windows XP SP2. (if that's any use)
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
you'd better try increasing the cpu cycles with ctrl-f12
Water flows down the stream
Reply 2 of 7, by D131
uh.. that sped up some of the games.. but for example x-com apocalypse still complains about memory issues. "Not enough memory to run X-COM: Apocalpyse" and the game is dos-based.. and sorry, I didn't notice that ctrl-f12 thing before when starting dosbox.. =)
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
well dosbox comes with configuration file. called dosbox.conf
it's in the startmenu somewhere.
take a look it has the memory size as well.
Reply 5 of 7, by eL_PuSHeR
dosbox.conf is a text-file. You can edit it using NOTEPAD, for instance.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 6 of 7, by D131
el_pusher,
yes, I know that ;>
well, ufo3 doesn't still work... but other games do. now the game just freezes when it starts up. guess I'm not playing ufo3 then ;/
Reply 7 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
ufo 3 is a problem game 😀
I recently fixed the cdrom detection. So you might have better luck in the next version
