First post, by GigAHerZ
- Oldbie
Good day,
I have a PC with Acorp 5VIA3P motherboard and i haven't been able to get any serial ports to accept mouse.
Then i tried loopback test (with norton commander terminal, i tested it with other computers and it works) and seems that both COM ports are dead.
What next? What could i try to trace or search? I hold soldering gun pretty firmly in my hand, therefore i'm not afraid to fix something, if it's possible. At the same time, i don't have too extensive knowledge in electronics, so debugging on that level is a bit over my head.
Anyone nice have some suggestions i could take a look at?
Thank you!
