SHARE command in DOSBox?
First post, by Harry Potter
Hi! I have a Win3.1 emulation running in DOSBox, and a Win3.1 program I just installed requires SHARE.EXE to be loaded before it runs. Is SHARE available in DOSBox? If so, how do I use it?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
it's not available.
you can use fakeshare which works with win3.1 stuff, although if you need the functionality itself, you have to look at a different program.
Water flows down the stream
Reply 2 of 6, by Harry Potter
Okay. Thank you. 🙁
Reply 3 of 6, by Errius
I could not find Fakeshar when I last looked for it, but did find a similar program that does the same thing, called Noshare. I uploaded it at the end of this thread:
Help loading fakeshar.com
I successfully got Office 4.3 to run with this.
Is this too much voodoo?
Reply 5 of 6, by Harry Potter
I downloaded it. Now to try it. Thanks! 😀
Reply 6 of 6, by Harry Potter
It worked! Thanks! 😀
