First post, by ruthan
- Oldbie
Hello,
i suppose that lots people here have some problem as i, too many cables.. and problem with their identification, are using some marking system, which one?
Im searching for something like this:
- cheap and available markers available world wide on eBay
- different size, or some solution of different cables thickness (diametrs)
- possibility to write some note on marker
- something durable, better than some paper stickers.. some paper / plastic combination is fine
- various colors
- nothing too big to block manipulation with cables
So far im using at less these:
https://www.ebay.com/itm/Newest-100pcs-RJ45-R … a1rNA:rk:1:pf:0
- problem - no notes, problems with too thin or too thich cables, only difference is only color numbers are the same on every item of same color 🙁 I didnt spend too much time on research of this stuff, i just used first thing which seems usable..
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
