IBM 300GL 6282 error 67
First post, by omarsis
Does anyone here have any experience with IBMs from around 1997/98? I have this IBM 300GL model 6282 that won't boot.
It crashes with the error or code number 67.
I changed the battery, clear the cmos config, changed the ram, I disconnected the hdd, I have no expansion cards.
Any ideas what's wrong here?
Video: https://youtu.be/m00e_mJF3bs
Reply 1 of 3, by oeuvre
It's related to the hard drive... reseat your IDE cable(s) and power connector(s), try another IDE cable if you can.
Reply 2 of 3, by omarsis
I found what the problem was. I removed the COAST L2 cache module, re inserted and then it booted OK
Reply 3 of 3, by oeuvre
Nice!
