Tomato 4DPS 2.0 + Cyrix DX2-66 - not work
Reply 20 of 22, by GigAHerZ
This is wrong way.
Where the "rear" arrow points? And compare it to the direction, where your rear vga port for example would be...
Reply 22 of 22, by Radar41
Card diagnostic is good.
I checked on another computer and it's working. Displays BIOS codes on the screen.
The problem occurs on the 4DPS board - there are lines on it
Edit
I just found information that rev 2.0 does not work from BIOS 1.72 and must be 1.6
Hmm, I'll check it
