First post, by PcBytes
- l33t
I just bought this in a pack with a Acorp 6VIA81P (which works) and couldn't for the life of me get it to ever POST.
CPU sometimes gets warm and other times it stays cold. One thing though, regardless if it's warm or cold, it won't POST, and won't BEEP at all. I should add I recapped the board with high quality capacitors (Panasonic and Rubycon)
I even tried without RAM and GPU - no beeps, CPU sometimes gets warm and sometimes stays cold.
I tried all kinds of CPUs:
Cyrix 6x86-P133+GP
Pentium-S 166MHz
AMD K5 PR100
AMD K6-2 350/400/500
Pentium MMX 200MHz
All CPUs were tested on two different systems (Totem TM-586TX4 for the Cyrix, Pentium and AMD K5 and ACorp 5VIA77 (VIA MVP3) for the K6-2s), all POST'd fine.
Any help? I'm at loss as to what I should try. I also used all kinds of GPUs, ranging from an 512KB ISA ATI VGA Charger to a Matrox Millenium 4MB PCI and even a Radeon 9250 128MB AGP, and have checked over 50 times that I set the jumpers correctly for the FSB.
