First post, by 9646gt
I have windows ME installed on my HP Pavilion 6475Z. ISpecs are:
Celeron 455 (OC to 583MHZ)
96 MB RAM (256MB coming soon)
Nvidia Geforce 3 ti200 (actually an Asus v8200t2 deluxe) that is overclocked to 230mhz CPU and 525MHz Memory.
Asus MEB-VM Motherboard (OEM Version) I think 440BX chipset
Monitor is Dell 2007FP
Software is:
Windows ME with Unofficial Cumlative update (this problem occurred on a fresh install before installing this)
Nvidia ForceWare 81.89
Internet Explorer 6 SP1
DirectX 6,7,9.0c
Here is the issue...I have disabled all suspend settings in the BIOS. Even HDD thinking they were causing errors. I left only Windows Power Management in place inside Windows. Every time the PC goes go turn off the display I get a blue screen that says
An Error has Occurred Tp Continue: Press Enter to return to Windows, or
Press CTRL+ALT+DEL to restart your computer (followed by info about losing date)
ERROR: 0E : 0028 : F000FF53
Press any key to continue.
If I press CTRL+ALT+DEL it reboots and forces me to click restore active desktop and usually the resolution has dropped all the way back to 800x600 16bit. If I just hit enter it goes to the desktop with only a quarter of it visible on the left of my screen like it is pushed off the screen.
I tried updating chipset drivers but it tells me the version of Windows I am using already knows how to handle my chipset. I have what I believe are the very last drivers for Win9x for my video card. If I disable all suspend settings in BIOS and Windows...no errors. Just stuck with tons of power usage 🤣. Any ideas? I have no Yellow "!" in Device Manager and Device Manager shows APM version to be 1.2 and has an option to force APM 1.0 and disable power status polling.
Mother Board Resources in DM shows a Input/output range of 0028-0029 is in use by something. And shows Memory Range FFFF0000-FFFFFFFF.
