Dead PC speaker?
First post, by The Serpent Rider
Recently I've acquired Intel LT430TX board with integrated PC Speaker, bur for some reason it does not function (external works fine). Is it even common for a PC speaker to just die?
Reply 1 of 2, by canthearu
http://www.elhvb.com/mobokive/Archive/Intel/L … TX_67703201.pdf
See Page 29/30
You need to bridge pin 26/27 of the Front panel i/o connector to send the speaker signal to the internal buzzer. Otherwise it won't get the internal speaker signal.
Reply 2 of 2, by Windows9566
Same with my AN430TX, i had to bridge the pins with a jumper for the speaker to work.
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
