First post, by StrangeD0s
I'm in a bit of trouble. I have this very old Pentium computer and it only has a DIN connector for the keyboard, two serial COM ports and a printer port. My old serial mouse is long gone and right now I'm having trouble finding a new one. So I'm thinking about alternatives. I have tried connecting a PS/2 mouse with an adapter to the COM port but no luck. I have tried connecting a PS/2 keyboard and mouse via PS/2 Y-splitter + PS/2 to DIN adapter, also no luck (the keyboard with the PS/2 to DIN adapter alone works fine btw.!). The motherboard is a Chaintech 5IFM M101 and after inspecting it closely I found free solder pads for a USB port (see pic)!
In the BIOS I have also found a USB controller that is disabled by default.
So can I just solder a USB header onto the motherboard and enable the controller in the BIOS to get USB support? And will that even help me if I want to play DOS games with a mouse?
Reply 1 of 9, by NJRoadfan
It might work if you have a later revision of the PIIX3 southbridge, see: http://th2chips.freeservers.com/5ifm0/index.html
Please note that the USB header on this board is NON-STANDARD. DO NOT USE OFF THE SHELF MODERN USB HEADER CABLES, they will likely fry something.
The board has a PS/2 mouse header on it. Best to wire up a port for that: http://th2chips.freeservers.com/cgi-bin/i/5ifm0/jumper.jpg
Reply 2 of 9, by StrangeD0s
Thank you for that helpful info! I will definitely try wiring up a port to the mouse header. That would actually be much more useful to me than USB. And my southbridge chip does not seem to be the right version anyway.
Reply 3 of 9, by Paadam
In 99% cases when you have USB headers then USB will work. And also more often than not when you have empty place on PCB then it would also work. I would give it a try, it is easy, just measure GND and +5v pins before actually connecting the header then you won't fry anything (if does not work swap USB+ and USB- data lines and try again).
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
Reply 4 of 9, by chinny22
not that it matters as it looks like your going with ps2 now.
But unless BIOS has "Legacy USB support" you wouldn't be able to use a mouse (or keyboard) plugged into the usb port from dos
Reply 5 of 9, by kaputnik
Wired up the headers on my Gigabyte GA586HX board (430HX) before, worked just fine after enabling the USB ports in BIOS. However, the ports are USB 1.0 (as opposed to 1.1), which means compatibility issues, even with stuff that is supposed to be USB 1.x compatible. Guess 1.1 interfaces were commonplace when USB got off the ground after a quite slow start, and most later peripherals omitted 1.0 support.
The PS/2 header is a much better choice for mouse usage in my opinion too 😀
Reply 6 of 9, by Windows9566
my Intel TE430VX has a spot for USB 1.0 ports, i wonder if USB ports that i desoldered off a dead Socket 462 board would make USB work on that board
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 7 of 9, by Errius
what is the difference between USB 1.0 and 1.1?
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 8 of 9, by kaputnik
As long as the USB header pinout on your TE430VX is the same as on that 462 one, there are no reasons why it wouldn't work. I'd be very careful checking that before connecting anything though, just as NJRoadfan mentions, the pinout might be non-standard. Was on my GA586HX board too. However, the +5V and GND lines are easily found with a multimeter, and swapping the data lines won't fry anything. Padaam explains it well in post #4 😀
No idea at protocol level, haven't read up on it (as if I'd understand it if I did 😁). Only know from personal experience that there are compatibility issues with some newer USB stuff. Older peripherals from before USB 2.0 was released generally seems to work fairly well though 😀
On a second thought, could be the driver implementation just aswell, using the driver included with W98SE with that GA586HX board.
Reply 9 of 9, by oeuvre
I want USB 1.1 over Type-C.
