VIDEO Patch for pixel-perfect scaling (SDL1)
Reply 540 of 733, by Yesterplay80
Did you remove the option "surface-collapse-dbl" or did I mess up something while adjusting the patch to the ECE source?
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 541 of 733, by Ant_222
I removed it. But my patch needs further work to handle double-width and double-height modes properly.
Reply 542 of 733, by Yesterplay80
OK, I just wanted to maku sure I didn't do something wrong. Your newest patch is integrated in DOSBox ECE r4180.3, ready to download from my site!
Reply 543 of 733, by Ant_222
Thank you very much. I am sorry to say that I made a serious error in the handling of double-height and double-width modes and will issue a fix soon.
Reply 544 of 733, by Pat86
Unfortuantely With openglpp i get tearing in fullscreen with fast games (Jazz Jackrabbit). Windowed is fine. With surfacepp there's no tearing in fullscreen nor windowed.
Reply 545 of 733, by Ant_222
Is the tearing present in vanilla DOSBox with openglnb?
Reply 546 of 733, by Pat86
In fullscreen yes, windowed its fine.
Reply 547 of 733, by Ant_222
Then it is not a problem of my patch, but I will see what I can do about it. Does anybody happen to know how to avoid tearing or turn on V-Sync in OpenGL via SDL 1.2? bladeSk's fork, for example, does it by faking fullscreen via a borderless window, but I fear his solution is not cross-platform. Another question, of course, is why is there no tearing with surface output? Is there still no tearing if you disable double buffering (fulldouble)?
Reply 548 of 733, by Pat86
Yes, even with double buffering turned off (btw. i'm using DBGL to configure), there is no tearing with surfacepp output in fullscreen. Turning on double buffering with surfacepp output results in quite a performance drop in fullscreen. very choppy main menu etc (Jazz Jackrabbit). yet windowed is fine again. 😉
Reply 549 of 733, by Ant_222
I wonder why.
Turning on double buffering with surfacepp output results in quite a performance drop in fullscreen. very choppy main menu etc (Jazz Jackrabbit). yet windowed is fine again. ;)
Because double-buffering is not available in windowed mode. It requires a hardware surface.
Reply 550 of 733, by Pat86
All my tests rely on Jazz Jackrabbit btw, as the tearing is very much present in there. Borderless window seems like a good workaround for the beginning.
Reply 551 of 733, by Ant_222
Either I am tearing-blind or there is no perceivable tearing with openglpp in fullscreen on my system with Jazz Jackrabbit. I shall be grateful if other users test openglpp for screen tearing.
Reply 552 of 733, by Pat86
Hm. Maybe it's a graphic card / driver specific thing? I'm on Windows 10 with an GTX 970 (latest driver)
I tried to record it with my smartphone (as OBS doesnt seem to capture it). Look at the threes at the beginning and you might see the tearing line going down consistently:
https://www.dropbox.com/s/fb1nr0o4fvgqiti/MOV_0014.mp4?dl=0
Reply 553 of 733, by krcroft
Pat86 wrote:
In fullscreen yes <snip>
Tested vanilla r4180 DOSBox on Linux, I see zero tearing with output=openglnb, fullscreen, with double buffering on or off. I've got plenty of native games that tear badly and have no problem seeing it. I'm using the CDROM version. My in-game configuration is: High graphic detail and [FAST] colors. My Jazz dosbox.conf:
[cpu]
core=dynamic
cycles=max 95% limit 30000
cputype=auto
[dosbox]
machine=svga_s3
memsize=16
[render]
aspect=false
[mixer]
nosound=false
rate=48000
blocksize=2048
prebuffer=20
[gus]
gus=yes
gusrate=48000
gusbase=240
gusirq=5
gusdma=3
[dos]
xms=true
ems=false
umb=true
[speaker]
pcspeaker=false
tandy=off
disney=false
[sblaster]
sbtype=none
Reply 554 of 733, by Ant_222
Can somebody please check the tearing with the attached patch?
Reply 555 of 733, by Ant_222
I saw it on my own machine once I knew where to look. The patch attached to the previous post seems to remove tearing. Can you try it?
Reply 556 of 733, by Pat86
unfortunately i dont know how to apply the patch - i just use Yesterplays ECE. 😒
Reply 557 of 733, by krcroft
Patched r4180 source, tested on Linux w/ fullscreen output=openglnb (same config as above). Zero tearing during gameplay, however at the starting menu, I could cause serve video lag and audio drop out when I rapidly moved my selection up and down in the menu. No lag during gameplay though (and I'm capping it at 30,000 cycles).
Also confirming the patch was active, as I saw this on the console: "Trying to turn on V-sync... ...success" roughly 4 times before I quit the game.
Reply 558 of 733, by Ant_222
Excellent! Thanks for testing.
As always, the question is whether you can reproduce this lag in stock DOSBox with openglnb.If V-Sync is the cause, I can add an option to turn it off.
You should see this message every time you enter fullscreen mode.
Reply 559 of 733, by Ant_222
Pat86 wrote:
unfortunately i dont know how to apply the patch - i just use Yesterplays ECE. :-\
Then you can try it when YP80 incorporates my alpha 18.
