Identification of 286 motherboard
First post, by root42
I just got this nice little Baby AT motherboard, with seemingly 1MiB of RAM plus parity, a 12MHz AMD CPU and very good visual condition. NiCd barrel not yet leaked. Will snip it off later, seems hotglued to the board.
Any hints on the battery removal?
I wonder what kind of board this is? Quick stason search did not help so far. However, it seems it might be the HAM 12:
http://www.amoretro.de/2017/08/ham-12-ti-286- … -10mhz-fpu.html
It looks in my opinion EXACTLY like my board. Most connectors are well labeled, however a few jumpers are not documented on the board. So does anyone have manual?
The attachment IMG_1007.jpg is no longer available
The attachment IMG_1008.jpg is no longer available
The attachment IMG_1009.jpg is no longer available
The attachment IMG_1011.jpg is no longer available
The attachment IMG_1012.jpg is no longer available
YouTube and Bonus
Reply 1 of 35, by weldum
that thing is really neat, it seems it supports SIPP modules, sadly i don't know anything of the 286 era
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 2 of 35, by keropi
You can insert 30pin simm sockets in the sipp sockets and it will work
As for the model I have no idea but generally 286 boards don't have many jumpers so even if a couple are not documented you won't miss anything important
Reply 3 of 35, by root42
Yeah, I will have to hunt for some SIMM sockets. Mouser doesn't have them anymore. RS seems to, but I haven't ordered from them yet. But the 1MiB is already a good start.
YouTube and Bonus
Reply 4 of 35, by GigAHerZ
If it's easier to find 30pin simm modules than sockets, you can solder a row of pins on to a simm module. 😉
Reply 5 of 35, by root42
I thought about that. I have a bunch of modules lying around. Maybe I'll try that.
YouTube and Bonus
Reply 6 of 35, by HanJammer
Nope, it's definitely not NEAT.
OK 😉 that joke was a bit niche...
Reply 7 of 35, by root42
OK 😉 this joke was a bit niche...
That joke was OA.K.
YouTube and Bonus
Reply 8 of 35, by brostenen
One question. Are those sockets for zip and not simm?
Reply 9 of 35, by gdjacobs
Definitely SIPP. ZIPP has two rows adjacent to and offset from each other.
Reply 10 of 35, by brostenen
Ahhh... Was not aware that there are both SIPP and ZIPP.
Reply 11 of 35, by gdjacobs
Yup. Very different.
Reply 12 of 35, by HanJammer
That joke was OA.K.
AM.I aware of that? Yes, but it was on the VIRGE of being funny (in fact it was A.BIT dry) so I don't expect any AWARD for it.
Reply 14 of 35, by dkarguth
holy crap that's my motherboard! (not mine exactly but it's identical to mine)
What a strange coincidence, I just located the document on stason.org yesterday. I just ordered some simm sockets from ebay yesterday, here's the link.
https://www.ebay.com/itm/Socket-Single-x-30pi … YJKhs:rk:1:pf:0
I will have extra, might consider selling to anyone who needs them.
I got 4 MB in SIMM memory from here:
I also know the pinout of the external battery connector if you need it.
It's a pretty nice board IMHO, even has very advanced built in diagnostics. The only problem is that it originally came with a matching floppy/IDE controller (that I may or may not have accidentally toasted) and it doesn't play nice with a lot of other controllers. I finally found one that it likes, though. It's the Acculogic sIDE-3/PLUS. The trick is to use its onboard bios instead of the mainboard bios to setup the hard drive. The onboard BIOS hard drive selector only works with the original card as far as I can tell.
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 15 of 35, by root42
Yes, please do document the battery pinout. I tried tracing the pins, but it goes through so kany diodes... my battery is still at 1.2V, and LOOKS good, but why risk a leakage, when I can safely use an external battery...
Not sure if I want to install SIMM sockets. The 1MiB it has is good enough for DOS games and for Windows 3.1 I now have the 386DX.
YouTube and Bonus
Reply 16 of 35, by dkarguth
Here's a picture. It unfourtunately had the battery leak all over the board, and ruined the AT keyboard connector and I had to replace it. I scrubbed it down, but some corrosion remains on the ground pads.
HT226Rn.jpg?1
Reply 17 of 35, by HanJammer
Test for continuity between any ground pad on the motherboard and pins of the connector and you will know the pinout.
Generally it should be like this:
(+5V) (NC) (GND) (GND)
Where +5V is usually pin 1, NC is not connected and rest are ground pins. Sometimes NC is keyed (no pin and connector has no hole) so you can't reverse the polarity by accident.
Reply 18 of 35, by root42
Oh the humanity! My book looks like it almost came out of the box!
Rumour has it that it supports up to 25MHz CPUs. Not sure about that though...
YouTube and Bonus
Reply 19 of 35, by root42
Traced the pinout, thanks to HanJammer:
The attachment E2B8EF0B-9921-40A7-8F91-16804EAA204C.jpeg is no longer available
YouTube and Bonus
