Mac Performa 6200 not recognizing CD-Rom drives
First post, by Windows9566
My Mac Performa 6200cd won't read discs and on the apple system profiler under SCSI Bus 0,
it shows gibberish characters
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 1 of 20, by Byrd
Is it the stock optical drive, or are you using a third-party unit?
Reply 2 of 20, by Windows9566
it's a stock AppleCD 600i
IBM Thinkpad 760LD
Reply 3 of 20, by Merovign
Is it the original stock drive, do you have another machine to test it on, and does the drive have jumpers to set for ID?
*Too* *many* *things*!
Reply 4 of 20, by Istarian
Was it working before or did you acquire the machine and it's never worked so far?
Maybe remove the cable connections and reconnect them making sure they're snug, as that looks like it's getting gibberish back from some command it's sending to the drive. Also double check the jumpers.
Reply 5 of 20, by Jo22
I think the same. Also, maybe that SCSi isn't properly terminated at some point (better check).
Reply 6 of 20, by mrau
but are the device ids not retrieved as numbers? and the names from a local driver database?
Reply 7 of 20, by Windows9566
it has never worked since i got it from ebay. i tried a board from a LC 630 and it works fine.
IBM Thinkpad 760LD
Reply 8 of 20, by Windows9566
i have seen gibberish too on a PC when the IDE cable is not connected to the drive/motherboard IDE controller, firmly. i reseat it and it works fine. i guess i'll need to fully dismantle the machine, thoroughly clean the connectors, then try again. the plastic on the CD Drive sled is super brittle that it cracks with ease, i guess the plastic doesn't age well.
IBM Thinkpad 760LD
Reply 9 of 20, by yawetaG
The SCSI ID is retrieved properly ("3"). What seems to be corrupted is the device information: manufacturer name, product type, eventual revision number (i.e. information stored in the device's ROM). This is the same kind of info that would show up in a PC's BIOS information screen. One reason for it not showing properly would be a badly connected cable, another would be defective device electronics.
Reply 10 of 20, by Windows9566
i bet there's no way to fix the defective electronics 🙁 it's just dead.
IBM Thinkpad 760LD
Reply 11 of 20, by Windows9566
i tried cleaning the gold fingers on the logic board/cd drive, checking the jumpers, etc. no dice. i guess it's faulty electronics. i just messaged the seller on ebay saying it's defective, hopefully i get a refund
IBM Thinkpad 760LD
Reply 12 of 20, by Merovign
In theory you might be able to replace the control board, probably cheaper and enormously less effort to replace the drive. Sorry. 🙁
Reply 13 of 20, by Windows9566
i just stuck to the 68k mac lc 580 board that i have, i have a working PPC machine anyway (Power Mac 6100/66)
IBM Thinkpad 760LD
Reply 14 of 20, by Byrd
Bad caps are also an issue on Apple optical drives (among others), but it's been clearly sold to you as faulty so I'd chase up another if you can.
Reply 15 of 20, by luckybob
Recap the motherboard.
Yes this sounds weird, but this is an issue with failing caps on ALL old macs. I have a 660AV. Internal scsi wouldn't work like you showed. a simple recap solved the issue.
Reply 16 of 20, by Windows9566
i didn't see any leaky electrolyte on the board
IBM Thinkpad 760LD
Reply 17 of 20, by Koltoroc
They don't have to leak to have gone bad, capacitors can still look perfectly fine despite having failed. That is why a visual inspection is not sufficient.
Reply 18 of 20, by luckybob
+1
The caps Apple used did not have longevity in mind in their designs. They were designed to work for a few years then pop like grapes. I've gotten to the place where I order caps before I even turn on an Apple product. They ALWAYS need to be replaced.
Reply 19 of 20, by Windows9566
i guess that apple didn't want to build their machines to last.
IBM Thinkpad 760LD
