First post, by appiah4
- l33t++
Replaced my P133's old motherboard (Taken PCI597-1) with a new one (QDI Explorer I PI5V430) and my serial port breakout bracket and/or serial mouse no longer works. Everything else on the motherboard works perfectly aside from the serial port.
The manual shows no pinout for the UART headers, and as far as I am aware there is only one header pinout for this after all? Could it be that this motherboard is meant to use a proprietary bracket for the serial ports?
What to do? Order another bracket and hope that one works? Just disable onboard COM and LPT ports and add in an ISA Multi-IO card?
