Strange 386 motherboard
First post, by n0m4d
Hello everybody! Sorry for my english, i comming from Poland and i’m pretty old guy, too old for language learning.
Enybody know something about this MB?
Reply 2 of 28, by n0m4d
Thanks for YouR answer. Nop, i didnt chekt there yet. What i know this motherboard is new, i dont know its true or not.
Reply 3 of 28, by AlaricD
That 96-pin connector is interesting.
Are there any other markings on the back of the board that might show a model number or a motherboard maker?
Reply 4 of 28, by n0m4d
Nop, its clear from behind
Ps. This motherboard was installed in this case, case Look like new, still with plastic cover on disiplay, little damage on panel, probably by shipping.
Reply 5 of 28, by quicknick
That's a nice looking board and a great find overall. Try identifying it on Stason, my guess is that the 96-pin connector is for a proprietary memory upgrade, and those sockets are always drawn on the stason sketches of the boards. Also, for quick identifying, the first and last ISA slot being 8 bit, and only 4 SIMM slots.
Reply 6 of 28, by AlaricD
I sifted through the pics and didn't see anything quite like it, myself.
Reply 9 of 28, by 386_junkie
I am currently searching high and wide for a specific 386 processor board with this very connector.
So far, I only know it to be Nubus connector from older Apple systems... now I know it is also called "Processor Direct Slot"... thank you very much for this.
To the original poster.... that is indeed a nice 386 motherboard, very unusual cache design that I have only seen in one or two other boards. I agree though with another poster that the empty connector is most likely to expand the Dynamic RAM, as there only are 4 slots available which you would really only see on a baby motherboard.... not this full length board, which would require more memory for sure.
Does the board function ok? You have tested?
Reply 10 of 28, by n0m4d
Yes, the motherboard is working, i ddidnt test it yet, but everything look like new, so i have Good feelings about this MB.
All i know it was bought for replace old workstation in company that i working now, but They never used this, becouse of system transformations in 1989 in Poland.
Reply 11 of 28, by elianda
Das benutzt den gleichen 286er chipset wie dieses: http://retronn.de/imports/hwgal/hw_mainboard_286.html
Ansonsten sind Boards mit dem 80385 nichtr soo selten, hier ist z.B. das CACHE-32A: https://retronn.de/imports/hwgal/hw_mb_chips_386.html
Youtube Channel
Reply 12 of 28, by n0m4d
What do you thing guys, is this missing part from my motherboard? Its called Hybrid Memmory Extension
Reply 13 of 28, by Predator99
Interesting, seems to match. But I would not dare putting this on my board without knowing 100% its the correct part...
What do you think the connector on my board is for? 😉
file.php?id=50681&mode=view
Reply 14 of 28, by n0m4d
Look at the „pass” sticker on MB And extension card, Look the same
Reply 15 of 28, by GL1zdA
I would guess it's one of these proprietary 32-bit expansion slots, before manufacturers standardized on VLB slots. They were often used for proprietary daughter cards, and they one you've posted looks exactly like one. I wouldn't attach importance to the "DIN" format of the slot - manufacturers used whatever was available on the market to create these slots (VLB used a connector borrowed from MCA, PISA slots looked like EISA slots).
getquake.gif | InfoWorld/PC Magazine Indices
Reply 16 of 28, by n0m4d
The memory expansion fits perfect to my motherboard, sadly it not working. Without ram motherboard can't wake up, its beeping, without ram, but with memory expansion nothing, MB can't boot, with ram and expansion its starting but its freezing during memory count.
Reply 17 of 28, by Predator99
You dont need that expansion, there is already 4 MB onboard. Was thinking your screenshots of the BIOS above belong to your board?
Reply 19 of 28, by rasz_pl
n0m4d wrote:
nice, try J25 and see what happens
