First post, by dicky96
- Member
Hi guys I got my Win XP / Fast Win 98 rig together and working
So far I have the following put together from 2nd hands bits:
Asus P4M800PRO-M mobo
Core 2 Duo 2.4GHz
2x 1Gb DDR2 533
64Gb SSD with Win XP installed
Samsung Super Writemaster DVD
Geforce 3 64Mb AGP
Cooler Master Centurion 5
I have some changes / upgrades to that planned when I can get the parts i want, but for now it works. I have another XP PCI-e rig with faster GPU.
So I want to install Win 98 and select my OS on boot. I've looked at creating a dual boot on the SSD and it seems a bit complicated to be honest.
However I was also wondering if I could install Win 98 on a second 64Gb SSD I have lying around, or for that matter on a 40Gb IDE HDD I have, and select the boot drive in the BIOS to load whichever OS I want. From what I can see the BIOS will allow me to select Master on IDE 1, IDE 2, SATA 1 or SATA 2 as first boot device. I am currently using SATA 1 (which the bios calls 'Master 3' in the boot sequence) to boot XP.
Would that work and would whichever drive i select in the BIOS boot sequence automagically appear as drive C: and could I then set the non booted drive (the other OS boot drive) as D: if you get what I mean?
So for XP boot from master 3 C: and master 4 would be allocated as D: in XP
For Win 98 boot from master 4 C: and master 3 would be allocated as D: in win98
I did try to google to find that out but wasn't really getting the info I wanted.
Rich
