First post, by TheMobRules
I've had a SE440BX-2 board for a few years, and it has me puzzled due to some video problems.
Years ago, when I first got this board, I paired it with a Diamond Viper V550 (Riva TNT) and everything was working just fine until one day I turned it on and heard one long beep followed by two short beeps (video issue), however despite there being no signal from the video card I could hear the HDD as Windows was being loaded and then the Windows start sound through the speakers.
After that incident the problem would occur intermittently, so I assumed the video card was on its way out and I replaced it with a Matrox G400 which worked just fine until I decided to disassemble the PC and the board went back to its box.
Fast forward to yesterday, I got an Intel 740 AGP video card that I intend to use in a new build, and figured that motherboard would be ideal, so I installed the card, a P2-450 CPU and a 128MB PC100 SDRAM stick and it fired up right away, the video signal from the i740 was great so I decided to run some Memtest passes for a basic stability test.
After a while the Memtest screen became corrupt with strange characters, so I decided to reboot (note that Memtest was still running without errors despite the character corruption). As soon as I pressed the reset button, I got the dreaded long beep followed by two short beeps with the system still booting without video signal. One thing I noticed before rebooting was that the heatsink of the video card was extremely hot, I was unable to put my finger on it for more than a couple of seconds.
So, here are my questions/observations:
  • Is it normal for the i740 chip to run REALLY hot when using the card on a DOS/Memtest environment? i.e. no 3D at all
  • Could the motherboard be killing the AGP cards due to some fault? Two old cards failing wouldn't be very surprising, but it makes me suspicious as I haven't had many cards of that era fail like that (the G400 still seems to work though)
  • I have used several known good PSUs from reputable brands (both old/recapped and new), voltages are all within ATX specs
  • Also tested with other CPUs and memory sticks
Basically I'd like to know if there is some way to determine if this is a motherboard issue as I wouldn't like to risk frying more valuable cards. I can live with the TNT and i740 just failing, but if it's the motherboard that is causing that then it would be sad as it's a great board...
Reply 1 of 5, by retardware
Does the BIOS offer manual override of the AGP voltages (for OC, OV etc)? If so, what are the current settings?
Reply 2 of 5, by TheMobRules
Being an Intel board, it has a very limited Phoenix BIOS... the only AGP option is aperture size (currently set to 64M).
I'll see if I can dig out some other board with AGP where I can test the i740 to confirm if it also runs hot and causes artifacts there.
Reply 3 of 5, by athlon-power
Have you checked the motherboard's capacitors and what-not? Some of those little components control voltage, and if one of the components relating to the AGP power draw is bad, it might be pumping too much/too little voltage into your cards.
I remember a video by the 8-bit guy where the CGA card in his Compaq Portable wouldn't work because of a similar situation. Granted, this was with technology 16 years older than your motherboard, but because of the sudden issues and the intermittent functionality, I'm going to assume it's a bad capacitor or some other bad component (I don't know specific electrical engineering very well, so I couldn't tell you much on the specific thing that might be dead other than a cap).
8-bit guy's video:
https://www.youtube.com/watch?v=5rPr2JSKeQ0
Where am I?
Reply 4 of 5, by TheMobRules
Well, looks like it was the i740 video card that just died. I tested it on another motherboard and sure enough, a series of beeps and no display.
Meanwhile both a Matrox G400 and a GeForce 2 MX seem to work fine on the SE440BX-2, which further confirms that the source of the issue was the i740.
Oh well, bad luck, but at least it was the card and not the board.
Reply 5 of 5, by Windows9566
maybe reflowing the BGA chip on the i740 could solve the issue.
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
