Reply 120 of 213, by ruthan
- Oldbie
I updated first post with my new retro Ultimate machine configuration. I have now new MB, case (Coolermaster HAF X 942, with 9 cards slots) and PSU, CPU + CPU water block, but its still under construction - WinXP and Win7, Linux are fine, but Win98 would need other ATI x800 card with different cooler, because of slots position design, which i have in other location. I finally have some nice per OS Bios profiles possibility, so make bios setting for OS, its now possible without hassle, with HP O.E.M MB, i only switched primary GPU and was lazy to adjust anything else, it worked, but i wasnt optimal.
I also have some minor problems, which need mostly only time (order on eBay, wait and test) to solve:
- some missing modular PSU cables for Enermax infinity PSU 650W, i ordered some generical cables to test, some maybe has to be modded manually, its still placeholder before i get Silverstone Nightjar fanless - which im using in other machine
- USB 3 controller in PCI-E 1x slot is not working, maybe because additional power is not plugged, because of some heatsink in way some modded molex would be maybe needed
- front USB2 ports are not working - missing front header cable, some cable which could be modded is on way
- i need some Fans 12V to 7V adapters to make some more silent.. I received with case 4 good (after i removed 4 leds on each) Dead silence 15 cm fans, but they could be more silent, otherwise Noctuas will solve it for some. Even without fans CPU is running fine on 4.3 GHz and could probably do more, i dont need it know, i need to add some reasonable Geforce 970 card for WInXP+ first
- i need some 8 cm Noctua 4 pin fan under cards slots, case have some special holder for it.. i it would need some fan cable Y cables (that 10 years old PSU has some Fan header cable too)..
- DOS, there MB has IDE controller, but its some Gigabyte special Sata/IDE controller (probably Micron chip one).. and so far typical DOS drivers.. XCDROM.SYS , GCDROM.SYS, VIDECDD.SYS are not working, so i would need other CD-ROM driver.
Only hard and complicated thing its really which additional cards to use and their optimal placement for best multiboot flexibility.. With this new case and MB, for example now have finally option to use two or even triple slots GPUs at the bottom without blocking some precious slots for other cards.. and Aureal and Yamaha combo.. or option to use only 1 sound cards and PCI videocard, i also have some PCI-E TV turner / video recording card - option now, which making machine even more flexible.
Its like IQ testing from movies and childhood toys, but there are much more of shape and their combinations..
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
