First post, by RetroFyre
So the number of possible PC builds is starting to get fairly outrageous. So anywhere I can cut down is nice. Right now I'm working on an XP\EAX build with a 780ti. The idea is to supersample XP titles that are EAX enabled (Doom3 etc). I'm aware that X58 is the last supported chipset, X67 has "partial support" and that anything after that is basically a hack.
And that's what I'm trying to understand, what does Intel stop supporting? I've seen that a couple people have Z370 motherboards on XP with 9900x CPUs.
Now I certainly don't want to go that far. I have a machine with 7 & 8 on it right now with a Z97 motherboard. I've conformed to Microsoft's Windows 7 requirements to receive support all the way through the extended guidelines. I like having a lot of OS options for weird programs and games and don't always want to use a port or "fix" when I can run it on hardware in the right OS\software.
So I'm not entirely interested in building a machine newer than this. However, I'm trying to understand what exactly I'm doing when I'm running Windows XP on for instance a Z97 chipset? What exactly would be the issue running a Windows 7 machine on a Z370 chipset?
As far as I understand, what I'm doing is using storage drivers designed for older chipsets to access SATA. Being that XP works on a 9900x, I'm assuming that intel basically releases final version microcode, but how was this changed with spectre\meltdown?
At what point do I transition into "hacky" territory?
I don't mind monkeying around with stuff if I can be sure that the drivers are 100% working properly. So in a lot of cases, I understand the driver lock outs are to transition users to the next OS. But I'm concerned about using drivers that were intended for different hardware, even if it "works."
From what I can see the X79 stuff for XP works flawlessly, because it does seem to be a case of locking users out to push them into Vista. But when I read about people on the Z370, it seems that instead, they are in fact running code which is not really written properly, that is working, somehow, but with lots of problems.
Put another way, what is the latest Windows XP chipset that with third party storage you would trust the Space Shuttle on from a theoretical, not practical standpoint?
Max. boost clock on reference GTX 780 Ti is 1020MHz (no Power/Temp limits), I locked to it (as can be seen in GPU-z).
