First post, by Intel486dx33
I am confused ?
Does this Overdrive CPU make your 486 computer into a Pentium computer ?
Intel Overdrive CPU ODP456DX-33 SZ802
Reply 1 of 15, by Vynix
That's still a regular rundown of the mill 486DX... You must be confusing with the Pentium Overdrive which IIRC has a modified Pentium core on a 486 socket.
Edit: Woops not exactly a regular 486... These were made to fit in 486 motherboards that had upgrade sockets.. Think of it as one of these 486 motherboard upgrade chips.
Reply 2 of 15, by Intel486dx33
So is this just an upgrade for an Intel 486sx CPU ?
Reply 3 of 15, by Brickpad
[EDIT]
Not quite run-of-the-mill 486s. There were some difference between a standard i486, and their Overdrive counterpart; per Wikipedia:
https://en.wikipedia.org/wiki/Intel_80486_OverDrive
ntel's i486 OverDrive processors are a category of various Intel 80486s that were produced with the designated purpose of being used to upgrade personal computers. The OverDrives typically possessed qualities different from 'standard' i486s with the same speed steppings. Those included built-in voltage regulators, different pin-outs, write-back cache instead of write-through cache, built-in heatsinks, and fanless operation — features that made them more able to work where an ordinary edition of a particular model would not.
A Pentium Overdrive for the 486 platform will look like this:
Reply 7 of 15, by Disruptor
gbeirn wrote:
Wrong. A 486ODP is a DX2-66 with the extra pin (FC-PGA169).
It should be placed in an overdrive socket. Question: Is this the same socket used for the 487 SX?
It may not work in every socket 1.
There also exists 486ODPR (R for Replacement) which is a DX2-66 without the extra pin (FC-PGA168).
Note that Intel has changed the label from 486ODP33 to 486ODP66 and 486ODPR33 to 486ODPR66 somewhen.
486 Overdrives operate with 5 Volt and do not require motherboards supporting 3.3 Volt.
Reply 10 of 15, by Scali
Deksor wrote:
Yeah, that's one of the most pointless Overdrive (the 169 pin one has some use), I have one ...
I have no clue why it exists, it's just a 486DX2 66
I think the point is that it has a heatsink mounted to it. Regular DX2-66 CPUs came without a heatsink, putting the responsibility for proper cooling with the OEM.
The OverDrive came with a suitable heatsink, so it was a drop-in replacement for any DX33 machine, which did not require a heatsink at all, so the machine would not have any special design for cooling the CPU.
I wouldn't be surprised if these OverDrive CPUs were cherry-picked by Intel for lower power usage, to minimize heat dissipation, where regular DX2-66 could be the more powerhungry ones.
Reply 11 of 15, by Disruptor
Marketing.
They've made the FCPGA-169 socket ODP cheaper than the DX2 because you still need the already paid SX or DX in your FCPGA-168 socket.
It's because Intel did not want you to install the Overdrive and sell the old SX or DX for use in another motherboard.
Later they've made FCPGA-168 socket ODPRs for motherboards that do not have a FCPGA-169 socket.
Reply 12 of 15, by Intel486dx33
Well going from a 468sx-33 to a 486dx-66 is not exactly pointless.
Not only do you get a speed bump but a mathco processor too.
Reply 13 of 15, by H3nrik V!
Scali wrote:
I think the point is that it has a heatsink mounted to it. Regular DX2-66 CPUs came without a heatsink, putting the responsibili […]
The "drop-in" part is the keyword here. AFAIK, it is exactly drop-in - as in - no jumper change or anything necessary.
Reply 14 of 15, by Cobra42898
http://chookman.id.au/cpu/processors/Overdriv … /overdrive.html
I thought these were the old 386 to 486 chips, but they are not. The website makes clear the numbering system is very confusing. Early ones were labeled with what they were upgrading, not what they actually were.
The 1989 date is what threw me off. Must be from the date of the original 486?
Searching for Epson Actiontower 3000 486 PC.
Reply 15 of 15, by Scali
No, they used the name RapidCAD for those: https://en.wikipedia.org/wiki/RapidCAD
Yes, probably the copyright date of the original 486 architecture.
