Athlon 64 questions
Reply 20 of 25, by frudi
I understand what the problem with the underfill was and why it lead to bumps failing. My objection wasn't that this isn't happening, merely to the idea that the problem would be exacerbated with passively cooled cards.
My experience with passive cards has been that while they run hotter under load, they also run a lot hotter while idle, meaning they effectively experience lesser temperature variations between load and idle temperatures than actively cooled cards. And while they heat up faster, they cool off a lot slower, which would again reduce thermal stresses.
At least, that was my reasoning. Though now, based on what you say, I'm thinking because bumps are so small, so close to the heat source (while also producing heat themselves) and opposite side of the cooling surface, that active versus passive cooling likely doesn't have much influence on thermal conditions in the bumps and underfill anyway. So there wouldn't be much if any difference in how passive and active cards are affected by this defect. Or am I understanding something wrong?
Reply 21 of 25, by Koltoroc
That is pretty much it.
Reply 22 of 25, by The Serpent Rider
However I've got my eye on a 1950 pro at the moment.
Go straight for that or Radeon X1950XT/XTX. Good performance and reliability.
Reply 23 of 25, by appiah4
I am using an X1950PRO AGP for my Socket 754. It was a tough call between that or the X800XTPE AGO but both are fantastic cards for 754/939 systems. If you are using a PCI-Express board you are spoiled for choices anyway. Any ATI/AMD card from the X800/X1800/X1900 Series as well as the HD3000/HD4000 Series will be fantastic in that case (just skip the HD2000 Series)
Reply 24 of 25, by Almoststew1990
I won the x1950 Pro for £8.50 (PCI-E 😉) so that's a bit more era appropriate and more interesting than the 8600!
Reply 25 of 25, by swaaye
I suggest running Catalyst 7.11 or older. Drivers after this have considerably worse support for older OpenGL games. And some DirectX 8 games have trouble too like Republic Commando.
I like the X1000 series. Great cards for many games. Nice 16-bit color dithering. Dual link DVI.
