Today's arrival :
This computer contains a working PCChips M912 (they seem fairly common actually) with VLB controller and VLB trident, a sound blaster 16 CT2290 with a 1748 chip in the socket !
HDD is 420MB seagate, and CPU is AMD 486DX4 with 8KB of write-back cache (1996 manufacturing date !)
The whole thing is kinda nasty and smells (when I scrub it with paper, I get brown remains on the paper), but I can get that off with some elbow grease.
There's also another incomplete system (it only came with 2 fdds, PSU, motherboard and a vlb controller, nothing else, the "U" shaped cover is also missing (but I have another case that's exactly the same, so I can swap covers).
Speaking of the motherboard :
Looks ok doesn't it ?
Well look twice
I have absolutely no idea what happened to that poor socket (the mobo came without any CPU, that DX2 is fine 😉 ), but the motherboard seems ok on the other side so I don't know ...
I've tried to turn on the mobo with the DX2 on the photo. There is some activity on the bus when the CPU is inserted and ram is inserted, but it's very slow and I can't get it to POST. Either this horrible thing in the socket or the fact the battery started to leak prevents the board from POSTing. Anyways, I think that will be one more motherboard to fix ... (And since it has fake cache, I'll also need to fix that)
in the meantime, I also bought a Sound Blaster 2.0 BOXED. Can't wait to receive that 😀 (especially because it's localized, so it's not even as common as english boxes !)
