Reply 11500 of 30562, by bjwil1991
- l33t
Probably because of the chipset issue with Windows 98SE. I had USB 2.0 work on a KM266Pro-MLV (DFI) board that has a buggy AGP bus when I enable the fast write and set the size higher than 32MB. Every other board I have (Shuttle AV18V31, FIC K8M-800M, and PCChips M871G v1.5) works with USB 1.1 and 2.0 in Windows 98SE without issues. Like I said, it's a hit and miss with certain chipsets that are used on the USB ports for Windows 98SE that can cause the crashes to occur whereas Windows XP would work regardless. I had a USB 2.0 card that would cause a bit of issues, but, I finally fixed it by installing the correct drivers and the chipset drivers for the motherboard.
