First post, by Dubinius
Hello there,
i had this 8 Bit HD Floppy Controller a long time, works nice - also with Sergey's Floppy Bios - But...
I need that original Bios Dump from the Card, it is known as MT883 Type and has an UM8398 UMC Floppy Controller and an 2764 BIOS Socket.
135.29 KiB
145.47 KiB
Will be very cool - also for Coolnes and Original Hardware 😁
Thanks
Reply 1 of 3, by dkarguth
A lot of older HDD/Floppy controllers didn't come with a BIOS installed, since the motherboard BIOS often takes care of the drives. Are you certain it had a ROM in it originally? Even if it did, the ROM was optional on most cards, and you just set the ROM jumper to 'disable" and it works just fine.
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 2 of 3, by Dubinius
Hi @dkarguth,
i saw this Controller as "MT883" with a 64kbit BIOS installed because it's a 1.44 MByte Version and XT's often lacks support at HD Disks.
It will be cool to have that original Dump of that bios - otherwise it can run with Sergey's Floppybios.
Lets see...
Reply 3 of 3, by Maxx1234
Here you are ... (see attachment)
    MT833.BIN.zip
    2.05 KiB
    63 downloads
    ROM-BIOS
