First post, by aries-mu
Hello fellow retro-enthusiasts!
I was wondering:
1) In your opinion, is it possible to do some hardcore hardware hacking like, for example, to:
• Take a PCI 486 Motherboard, de-solder ALL the components pertaining the PCI bus (chipset, various chips, capacitors, etc., and the whole PCI slots section)
• Then take an ISA-only 486 Motherboard and, with soldering iron, wires and other stuff, kind of interface the above parts with it, so that the ISA-only motherboard now also has a working PCI bus subsystem (it doesn't have to be on the same actual "board", even on an add-on card connected by some flat IDE-like homemade large cable or something...)
• Then hack the (formerly) ISA-only motherboard's BIOS to "add" whatever it needs to properly "see" and "use" the newly transplanted hardware
• And have it work well with PCI cards too?
2) If point n. 1) is possible, could you please list all the subjects one should learn, in chronological order, to be able to design, develop, and achieve it?
Thanks!
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
"physical media trumps cloud-simp servitude" (Conrad Riker)
Computers should be fun inside not outside! 😉 (by Joakim, VOGONS)
Reply 1 of 30, by canthearu
Why not use the PCI 486 motherboard as it is? It will have ISA sockets.
I must admit to being utterly confused your thinking process here.
Reply 2 of 30, by meljor
Point 1: Sure, anything can be made.
Point 2: This would be the extremely hard part, knowing HOW to do it...right?
Point 3: Any more crazy questions?
Reply 3 of 30, by aries-mu
For the sake of modifying an old favorite ISA only 486 and enjoying it run on PCI! 😎 😁
Great! But, can it be made via DIY at home with home stuff?
Hence my question...
Sure! There you go: (yes it's mine)
https://www.linkedin.com/pulse/more-questions … cola-di-pietro/
Thanks!
Reply 4 of 30, by canthearu
I'll make it simple
Its not really possible, you would need to change the chipset, you would need a new BIOS and a new board. It would turn out to be the same as the donor board you took the PCI chipset from, rather than your favorite ISA only 486.
Reply 5 of 30, by Errius
https://www.youtube.com/watch?v=LPW70q4w5pw
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 6 of 30, by aries-mu
canthearu wrote:
I'll make it simple
I see, that's sad! It would defy the whole purpose of having THAT particular ISA only 486 run with added working PCI too, too bad!
Unless... can't a motherboard have 2 chipsets and 2 bioses, like an extension? (LOL)
Reply 7 of 30, by aries-mu
Errius wrote:
omgosh!
Reply 8 of 30, by rasz_pl
Its not possible due to signal integrity issues surrounding soldering a spiderweb of wires in the air. On the other hand its totally possible to build VLB card with PCI bridge, or CPU interposer with PCI bridge 😮)
Some basics in reverse order (from difficult down to bed reading material), you should be able to get pdfs or rent:
'High Speed Digital Design: A Handbook of Black Magic' by Howard Johnson. Highly approachable video featuring two absolute legends: https://www.youtube.com/watch?v=e0Uv5Zd9wXM
http://alternatezone.com/electronics/pcbdesign.htm
Digital Design with an Introduction to the Verilog HDL by M. Morris Mano - logic basics
The Art of Electronics by Paul Horowitz and Winfield Hill - absolute bible, expensive so rent
Microprocessor Theory and Applications with 68000/68020 and Pentium by M. RAFIQUZZAMAN - quite readable cpu interfacing basics
Invitation to Computer Science by G.Michael Schneider - another light read
Logic & Computer Design Fundamentals by M. Morris Mano - very easy to read
Upgrading and Repairing PCs (somewhere around 10th Edition) by Scott Mueller https://archive.org/details/URP_8th_edition
Learn this and we can talk some more 😀
hunger for knowledge? I admire his enthusiasm, reminds me of spending whole summer trying to mod old one channel CB radio instead of working ~7 days to earn for brand new one 😀
Reply 9 of 30, by Deksor
What about making a PCB you clip on the chipset (kinda like they do with Amiga 600) and then let the user have working vlb (as far as I know, VLB is just the bus sitting inbetween the CPU and the chipset/ram, right ?)
Reply 10 of 30, by ph4nt0m
Just no.
The chipsets have very different pinouts. You can design and order your own DIY PCB and install all components there, but it's complicated and very much time consuming.
My Active Sales on CPU-World
Reply 11 of 30, by rmay635703
It may be possible to add VLB bus off the 486 cpu socket, the same way you can add a passive ISA backplane off the right cpu pins on an 8088.
Trouble is you would need a cable like the 80pin ide cable that could work around all the noise issues and god knows the shape and ground plane issues that would occur at the socket
Reply 12 of 30, by aries-mu
rasz_pl wrote:
Its not possible due to signal integrity issues surrounding soldering a spiderweb of wires in the air. On the other hand its tot […]
Wow man!!! THANK YOU SOOO MUCH!!!!! Who are you?? 🤣
ph4nt0m wrote:
Just no.
Thanks guys, it seems more and more doable...
Reply 13 of 30, by rasz_pl
I recently stumbled onto this IBM riser card http://ps-2.kev009.com/pcpartnerinfo/ctstips/c892.htm
goes into this 486 VESA motherboard http://ps-2.kev009.com/pcpartnerinfo/ctstips/a5a2.htm http://ps-2.kev009.com/eprmhtml/eprm/f347.htm
and converts VESA bus to PCI 😀 Seems IBM was the only vendor to implement optional PCI bridge, they called it SelectaBus.
http://www.members.aon.at/mcabase/mcb/tli/rc_PC137x.htm
fru 88G4255, 88G4265
Sadly it as only used in few models manufactured for a ~year, so its pretty much unobtanium, otherwise it could be a great candidate for modding
Reply 14 of 30, by Ozzuneoj
Wow, I can't even imagine the compatibility nightmare of a VLB to PCI bridge. Yikes! 🤣
Reply 15 of 30, by aries-mu
wow, nightmares apart indeed, that's a very interesting and juicy piece of hardware! Thanks rasz_pl !
Reply 16 of 30, by rasz_pl
VESA/LocalBus/VLB is just a fancy brand name for providing hardware access to CPUs 32bit data bus, IBM just made PCI bridge an optional add-on while later designs incorporated it on board, electrically makes no difference.
Reply 17 of 30, by ph4nt0m
VLB is a direct extension of the 32-bit system bus. It may be implemented on 16-bit and 64-bit system buses, too, with a buffering logic. There is no VLB to PCI bridge because it doesn't make sense. A host to PCI bridge is needed. Could be a custom ASIC or FPGA.
Reply 18 of 30, by Deksor
Well it have been implemented on 16-bit platforms : I've seen a Ti486SXLC2 motherboard with a VLB connector once here, so that have been made. It also have been made for pentiums, but here I think they've just turned all the memory busses into 32-bit busses as the chipset on these usually work with only one 72 pin RAM stick and have terrible memory performance.
Reply 19 of 30, by BinaryDemon
Lets get real ambitious and blend some MCA slots in there as well.
