First post, by MKT_Gundam
- Member
nothing stops you modding it, from memory it was really simple, one wire + removing one pin?
wrote:nothing stops you modding it, from memory it was really simple, one wire + removing one pin?
The slotket dont have any indications for for p3 coppermines. I guess if the the Overclock/auto jumper is to change the FSB for 100mhz but not sure if Mendocino accept the high FSB.
Anyway, i just have coppermines only (733mhz, fsb 133 and 1ghz, fsb 100) to try).
I find this site; http://www.oocities.org/_lunchbox/generic_slotket_mod.html about the moding the slotket and the model looks like mine.
My actual rig dont suppor theses CPUs ( asus Pa-99) but i have the P3V4X, supporting the p3 cpus
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
If you read thru these two posts you'll see that this slotket seems to support coppermines at least 1GHz
https://www.wimsbios.com/forum/cpu-isn-recogn … -100-t8697.html
https://www.dell.com/community/Desktops-Gener … G1/td-p/2176473
