First post, by bakemono
I'm not big on patience. The time to get a directory listing on a network share has been bugging me lately. I have Gb ethernet, so copying large files is quick enough, but waiting for a file dialog box to come up or even doing DIR at the command prompt still takes a little while.
In a local directory these things are near instantaneous. Doing "DIR" takes about 1 second for 3,000 file names to scroll by.
On a network share, it takes 5-10 seconds. Running Wireshark on the host machine shows about 200 packets being generated by this operation.
If I use Opera to browse the directory it is much worse. Takes 30+ seconds and generates 13,000 packets.
It shouldn't be a bandwidth issue, since Gb ethernet would be just as good as ATA-100 in theory. It must be an issue of protocol overhead or latency? And latency should be low on a small LAN?
