Reply 28480 of 56741, by Thallanor
wrote:Your trip sounds way more exciting than my trip to the Windy City. Looking forward to your progress on this.
It was a fun road trip, apart from the couple times we almost hit the ditch. You know it's bad when the car starts to drift and all conversation stops and everyone is dead silent while letting off the gas and slowly nudging it back into the lane. It was also fun to ride a ferry to cross a lake to get to the seller. 😀 Then nerding with a couple friends over beers in the hotel room while poking at the computer. I didn't bring any tools or cables, but we found that the hotel television used the same power cable, which was honestly surprising.
I popped off both side panels, which both had slight signs of someone having removed before (a couple light gouges around the holes where the clips are and then one of the interior shields missing three screws and where there should be torx screws, everything was replaced with flathead screws). I've not dug any deeper than that.
Honestly, my next big project is still the Pentium Pro stuff. This just came up because I saw it for sale for dirt cheap and even with the seller not knowing if it still worked, it was worth it for the cost and how cheap the road trip was. (The cost was so low that even if I _knew_ it didn't work, I'd still have likely bought it.) In the end, the friends that came with chipped in enough for fuel and for the hotel room that the entire thing, including the computer itself, was less than what just the hotel would have cost on my own. So pretty reasonable. 😀
