ahh so 2 1 1 1 never worked for me on the biostar so I took it as a benchmark and did all the testing on 2 2 2 2. Just tried the atc1415 at 2 1 1 1 and got 17.3
Going back to the biostar I still get invalid command.com or sometimes boots but quake quits with a page error.
By double banked do you mean using 1 cache chip per 2 banks? bottom pins of 1 bank and top pins if second?
If so then no.
I never used the bios you told me about because you said WT is enabled by default in stock bios and I am only using 32mb so there is no need to disable it hence no performance boost from the modded bios.
I am using 2 matched 16mb fpm 60ns single sided ram chips I know its not ideal because 2 chips but next best thing I got is a double sided 32mb chip but it is 70ns apparently (I tried both combinations of rams on the biostar and they both get 16.6 on 2 2 2 2
One time I was lucky to get a benchmark with 2 1 1 1 and 1 x 32 fpm 70ns chip and got 17.0 fps so still lagging behind atc1415
the act1415 and luckystar I used the same umc cache
The biostar is in a case so it was too hard to swap cache and this is the cache biostar has
This is a biostar v3 I do have a v2 also maybye ill try that for comparison too
