First post, by keropi
Hello!
on SB2.0 cards there are 2 jumpers called JP12-FM and JP13-VOICE :
What do they actually do? Does JP12 for example disables the onboard OPL2 completely or it remains active on the bus but the SB MCU ignores it or something?
I assume the same would apply to JP13, does it disable the SB part?
Any clues about this?
Thanks! 😊
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 6, by keropi
yes I have but I cannot test until Monday morning... if I "disable" FM do you have any idea what can I use to test if the system sees the OPL2 or not? Maybe some adlib game?
Reply 4 of 6, by Cloudschatze
Those are not jumpers, but rather, output headers, intended to be connected to the corresponding mixer input headers of the uncommon SB2.0 CD-ROM interface card (CT-1800).
Reply 5 of 6, by keropi
Oh, so if you "disable" fm for example by putting a jumper there what you actually do is grounding it's audio output, correct?
I am not even sure now if just pulling the ym3812 is good as it will leave several floating pins on the board... Thanks Cloudschatze for that rare info 😀
Reply 6 of 6, by SirNickity
I just got a 1350B in the mail today and was wondering the same thing. I thought I had heard about them being output headers, but couldn't really think what they would be used for.
Documentation on these things really could stand some improvement. I still have no idea what many of the jumpers on some of my sound cards actually do.
