Reply 11760 of 30555, by oeuvre
Nabbed + restored this beauty yesterday.
Dell Dimension XPS T500
Intel Pentium III 500MHz Slot 1 processor
128MB PC100 SDRAM
DIAMOND Viper V770D 32MB AGP video card
3.5" floppy drive
IOMEGA 250 Zip Drive
CD-ROM drive
13GB IBM hard drive
Windows 98 SE
YAMAHA onboard audio
Netgear FA310TX PCI ethernet card
56K PCI modem
This thing had many scuffs + dust everywhere. Nothing a magic eraser, damp paper towels, and an air compressor couldn't fix!
Rear
help me I've broke apart my insides
dat Diamond Viper V770
other side
ethernet card
desktop
Programs
Programs 2 + system info
Specs
Reply 11761 of 30555, by appiah4
Nice!!! You also had a D333 too, no? Maybe post them side by side? I hope to find a T___ to display alongside my D333 someday as well 😀
Reply 11762 of 30555, by oeuvre
Oh I got rid of that machine a long time ago. Right now I have my laptop, desktop, an Optiplex 330 and this.
Reply 11763 of 30555, by keenmaster486
I had one of these once upon a time. It was a hand-me-down from my dad, who used it as his primary machine around 2000-ish. Some of my earliest memories of computers are when he had this Dell.
The differences to yours were: Voodoo 3 3000 AGP, 64MB RAM, 5GB Maxtor HDD
I cut my teeth with computers on the good old T500. I still have the guts of it, even the original hard drive which, amazingly, still works like a champ.
World's foremost 486 enjoyer.
Reply 11764 of 30555, by brostenen
I was looking for a solution, in order to be able to use a 5 volt VIC-II chip in a 12 volt Commodore64 board. It turns out, that there are no adaptor or PCB, so I had to cook something up. Made a quick and dirty solution. No time to test, too late. I made sure that Pin-13 did not make electrical contact between the board and the top socket. Then soldered a wire between Pin-13 and Pin-40. Hopefully the solution is not too high. At least this is a prototype or what it can be called.
The attachment VIC-II-5volt-01.jpg is no longer available
The attachment VIC-II-5volt-02.jpg is no longer available
Reply 11765 of 30555, by Gered
Still fiddling with IBM Thinkpad stuff, this time with a T20 (2647-86U) I picked up for cheap that was described as not working and did not come with a charger. Thankfully, these models are compatible with the charger for my old R52 I used in college, so that was no problem for me. Plugged it in and it started up, but was immediately blocked by a BIOS error for the date/time followed by the prompt for the BIOS supervisor password. Can't set the date/time without access to the BIOS, and can't enter the BIOS without the password, and the system would not continue booting without the date/time set (even just hitting enter without entering any password would not work). Boourns!
Was not really willing to spend more money to buy the fancy tools people use to dump the EEPROM chip that holds the password, but I google'd around a bit anyway to see what if any other methods there might be to at least skip the password prompt or something. Saw some Youtube videos about shorting pins on the ATMEL chip, but they did not exactly match the chip in my T20 (an ATMEL 24RF08CT which has almost twice as many pins as the ones these videos show, and the SCL and SDA pins are not right next to each other anyway). But, I decided to experiment anyway.
Eventually, through much trial and error, I found out that shorting the 4 bottom pins on the right-hand side (the side opposite the circular indentation on the face of the chip) approximately one second after the computer beeps just when the startup Thinkpad logo is about to disappear and the date/time error message is about to be displayed would skip the password prompt and take me directly into the BIOS.
However, it put me into the BIOS without supervisor permissions so I could not change some things (such as the date and time). Confusingly, after hitting F10 to save and exit, the laptop restarted and still gave the same date/time error with the supervisor password prompt showing up, BUT this time simply hitting enter at the password prompt allowed me to proceed through, allowing the laptop to continue booting (this was not possible before, believe me I tried!).
So, I still don't have full access to the BIOS but it's at least now able to do something other then serve as a paperweight.
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Reply 11766 of 30555, by oeuvre
Restored this IBM Model M 1391401
Reply 11767 of 30555, by PTherapist
The DDI-5 USB HXC Floppy Emulator + 512KB RAM expansion for my Amstrad CPC 464 arrived today.
It wouldn't work properly at first due to the expansion port being caked in layers of dirt & dust. So I took the Amstrad apart and throughly cleaned it all out and used a combination of a pencil rubber & isopropyl alcohol to clean the contacts on the expansion ports. Whilst I had it apart, I also sprayed some contact cleaner onto the Volume Control to stop the crackling when volume is adjusted.
All working great now and I've been loading games onto a spare USB stick for testing. This thing is quite picky about what USB sticks it will accept though. It didn't like the 16GB stick I was originally going to use, so I'm temporarily using a 512MB stick until I can track down something better.
Also loaded the CP/M disk images onto it and had a quick play around in CP/M. I'll probably start playing around with CP/M software this weekend to see what this thing is capable of.
Played some 128K Amstrad games too, to test out the memory expansion. I love the speech on Robocop. 🤣
Reply 11768 of 30555, by MMaximus
HanJammer wrote:
You know your Kalok HDD is a girl, when you power it on and starts blowing a lot of pink smoke!
Is this a KL-320? or 330? I got two 320s... they make a great sound 😎
I love ST-157A as well, we seem to have the same taste in hard drives 🤣
Hard Disk Sounds
Reply 11769 of 30555, by wiretap
luckybob wrote:
Replacing the guts would have been plan A if ever I was in your position.
Plan b would be using new high-temp caps and mosfets.
Update.. replaced the fuse and caps, plugged it in anddddd POP. Failed MOSFET. Oh well, it was worth a shot. Definitely not desoldering all the crap in there to get at it. Ordered a FSP400-60FGGBA Short-length Flex-ATX 400w power supply I'll be using to replace the guts with. Also ordered some slightly quieter Bgears b-Blaster 70mm fans (48cfm @ 4500rpm) to put inside the IWILL power supply chassis with the guts swap. Hopefully speedfan can control the fans on the motherboard headers, or maybe the BIOS supports it.
My Github
Circuit Board Repair Manuals
Reply 11770 of 30555, by brostenen
Got an VIC-II 5volt chip running in a board that delivers 12volt, using the adaptor that I hacket together yesterday.
The picture is not spot on. Still have those jailbar/vertical lines, and still have that red and green colour artifact.
Yet it is working.....
The attachment VIC-II-5volt-03.jpg is no longer available
The attachment VIC-II-5volt-04.jpg is no longer available
Reply 11771 of 30555, by PTherapist
My retro activity for today, got SymbOS running on my Amstrad CPC 464:
A bit of a novelty, but nice to use something that is able to see all 576KB of my RAM!
Tested out all the included apps and downloaded a couple of others. "Speech" provided some small amusement. 🤣
Reply 11772 of 30555, by liqmat
PTherapist wrote:
My retro activity for today, got SymbOS running on my Amstrad CPC 464: […]
That's just got a cool factor to it. Not very familiar with the Amstrad, but I know somewhat of its limitations so seeing that OS running on it is just neat.
Reply 11773 of 30555, by yawetaG
Googled around to find more information on an expansion card for one of my synths, found this ancient copy of the Roland JV and XP synthesizer FAQ on a Chinese forum: http://www.audiobar.cn/forum.php?mod=viewthread&tid=31801.
Tried to follow some of the links, found this awesome MIDI page that has a crapton of old software: http://archive.cs.uu.nl/pub/MIDI/ However, the Archive.org version shows it once hosted even more software - unfortunately the links to the ZIP archives are dead in most cases on Archive.org.
Googled the program name that interested me, and found not one, but two additional versions of what appears to be the same software archive, hosting the software I was looking for (Canvasman, a Win 3.x librarian for the Roland Sound Canvas):
ftp://ftp.ucsd.edu/midi/
ftp://ftp.monash.edu.au/pub/midi/
Reply 11774 of 30555, by mikeyp
I replaced the failed motherboard in my second hand Toshiba T3400CT notebook and it lives once more! I then discovered the mbr was infected with the V-Sign virus. Thanks previous owner. I've removed it by booting from a clean DOS boot floppy and running fdisk /mbr to rewrite the boot sector. It's no longer infecting floppies I put in so that's something. I'm still debating whether I format it and start with a clean installation of DOS and Windows 3.1 or whether I continue with the previous owner's installation as it works fine and is full of history.
Reply 11775 of 30555, by jheronimus
Made my first attempt at retrobriting today.
Before:
It's a face panel of a 1998 ATX case. I don't know the model, but I really like the case — looks similar to some of the pre-Jobs PowerMacs.
Notice how every piece of this case yellowed differently. The worst offenders are the faceplates of the CD and FD drives.
After:
I had to make the closeup photo, because otherwise it would seem completely uniform. The colors are still a bit off, but it's not that noticeable. Even the bright spot where a "Pentium III" sticker was is now gone.
It took around 3 hours for the whole piece, after that I've put the FDD faceplate separately for the remaining 3-4 hours of sunlight. I've used 14% peroxide (hair solution). Overall, I'm quite happy with the results, but I plan to make another go tomorrow.
MR BIOS catalog
Unicore catalog
Reply 11776 of 30555, by Tetrium
Been collecting and sorting all my games.
They were basically spread across several rooms, stashed away in boxes and big shopping bags. Part was in my living room, which holds the games I tend to use more often.
I find it kinda hard to make up my mind in what the best way will be to store which games where, but I also want to have everything together where they belong. I typically get several copies of identical games and I want all copies together.
I'll do a headcount later, but at first glance I don't appear to have nearly as many games as I thought I would have 🤣
But it sure is fun browsing through all those boxes again 😀
My retro rigs (old topic)
Report spammers here!
Reply 11777 of 30555, by TheAbandonwareGuy
The entire rear IO of my main PC appears to now be electrified. This concerns me greatly.
I should probably rebuilt this PC tomorrow.....
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 11778 of 30555, by Turbo ->
Having some hard time with Phoenix 286 BIOS. Doesn't let me enter HDD parameters, for the hard disc I have (81Mb) and it is not in the Phoenix BIOS 1-49 list. Any suggestions?
Reply 11779 of 30555, by brostenen
On my 286 with a Phoenix BIOS. I had a 840mb HDD running. I left the BIOS settings for the original 20mb MFM as they were, and installed a drive overlay on the new HDD. Did not make any further testing, just ran it with a standard Dos installation after the drive overlay installation. I was able to use more than 20mb of HDD space for storing games and so on. Ran overall fine. Did not feel era appropriate, so I installed an Adaptec SCSI controller and a 80mb Conner SCSI HDD instead.
