First post, by Peter Swinkels
As stated in the subject line, I am trying to use the DOSBox debugger on a laptop which does not have a full keyboard. This means there's no pause key to be found (and no it's not FN+some other key) and I am unable to pause DOSBox for debugging.
While changing the keybindings in DOSBox does give me a pause key the debugger doesn't seem to recognize it. Other than finding an external keyboard to use, I see no other solution. Does anyone have any suggestions?
Thank you.
My GitHub:
https://github.com/peterswinkels
