First post, by Intel486dx33
The onboard IDE ports on my Lucky Star LS-486 are not working right.
When I select to “Detect Hard-drive” in bios the Hard-drive turns up as a slave.
The Selector pin on the hard-drive is setup to Cable Select, I also tried Master and that did not change anything.
Hard-drive is a NEW WD-5420 540mb IDE hard-drive.
I am using NEW IDE cables and I already swapped them out twice.
The bios setting do not hold and after I select save in bios it restarts with no drives selected /
Hard drive settings in bios do not hold after restart.
New battery, All other setting remain the same just the hard-drive settings do not hold.
What do you think could be wrong ?
IDE Cables ?
