Reply 28740 of 52983, by arncht
early rev asus v6600 (gf256 sdr) - in 1999 manufactured
655.6 KiB
the very common audigy 2 player for my athlon xp rig, i did not find a platinum.
1.03 MiB
Overdoze of the demoscene
Reply 28741 of 52983, by Intel486dx33
wiretap wrote:
Picked up a Terratec DMX 6Fire w/ front panel today for $28.
The same seller also has a Terratec EWS 88MT for $29 if any of you are looking. Ebay seller is: altairman007
He's got a pretty low number of sold/purchased items, but so far there's been good communication, and he tells me that he's selling off some of his studio equipment.
I built my Terratec Audio studio PC awhile back. That EWS-88MT is missing the rear connector on the bay drive.
But I made a diagram on the pin-outs if anyone is interested.
Terratec EWS-88MT adapter mod advice ?
These Terratec sound cards and drives and terratec apps work good in Windows-XP too but not officially supported.
Just use backward compatibility in WinXP for apps.
    978.37 KiB
Reply 28742 of 52983, by Tetrium
SpectriaForce wrote:
Very nice. These cards have the potential to substantially increase in value.
Awesome. You can easily triple your investment if you want to sell it with a little bit of work.
From time to time this hobby seems more like a stockexchange 🤣
My retro rigs (old topic)
Report spammers here!
Reply 28743 of 52983, by deleted_nk
Went op-shopping (thrifting) and managed to find two pairs of 10 5.25 double density floppies for 2 bucks each. Normally I don't bother with them, but these were sealed and looked unopened. And being 360K disks, that was an extra bonus. Thank you very much, I'll be taking these. 😈
100% error free certified! Apparently 😜
Now that's something I haven't seen for a while. I guess we'll see if their claim holds up after 35 years in the shrinkwrap.
Being double density, these should work fine on my C64 as well as my 486, should the need arise to use them on the latter. Unfortunately my 5.25 drive in the 486 isn't exactly in the best of working order (needs a good disassembly and cleaning as well as lubrication), so I might keep a disk aside to test with later on. But at least I'll have something to make C64 disk images on.
Reply 28744 of 52983, by jesolo
ninkeo wrote:
Went op-shopping (thrifting) and managed to find two pairs of 10 5.25 double density floppies for 2 bucks each. Normally I don't […]
Nice find - preferably, you should write to and format these disks in a 360 KB drive and not a 1.2 MB drive.
Reply 28745 of 52983, by Murugan
Not too much lately because I am moving to a house next month.
Only some 'recent' HW: XPS M1330 (now I have the 3),a boxed 4870x2 and an Alienware Aurora ALX.
Reply 28746 of 52983, by arncht
the p120 and the 16m edo in the right place (intel advanced/zp, socket5, 430fx triton)
    596.65 KiB
Reply 28747 of 52983, by Gona
arncht wrote:
Speed, compared to the triton?
Must be slower than Triton. I will compare the VLB graphics performance to OPTi Python.
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 28748 of 52983, by appiah4
I got my Rage Fury MAXX in the mail but it was so fucking TERRIBLY packaged that one of the heatsinks got knocked off..
It was originally glued on with (apparently) thermal epoxy, how do I glue this back on? Doublesided thermal tape? I'm not keen on scraping the residue off the chip..
Reply 28749 of 52983, by Deunan
If you want the heatsink to be in proper contact with the chip you'll have to scrape the leftover epoxy, no way around it. Depending on how well it's bonded it might actually come of the chip easier than the metal part. And if you don't much care for the chip markings then sandpaper is going to make short work of it anyway.
After that it's either glue or strips of doublesided tape - take your pick. Both work equally well and are a pain to undo (well that's the point that it holds the heatsink well). I think tape is easier to work with though.
Reply 28750 of 52983, by rasz_pl
does it even work anymore? this magnitude of force is more than enough to crack some balls under the chip
Reply 28751 of 52983, by appiah4
I haven't tested it yet.. My hope is that 20 years made the epoxy brittle enough that it broke off without requiring too much force. I will restore it to at least cosmetically fine state, then try it. If it works, great. If not: 🙁
I sincerely hope none of the ball joints are cracked.. Worst case, I will give it a bake in the oven?
Reply 28752 of 52983, by ph4nt0m
This thermal glue can be dissolved by acetone or kerosene. The white paint isn't sensitive to these.
My Active Sales on CPU-World
Reply 28753 of 52983, by appiah4
A sharp modeling knife and much patience later:
Reply 28754 of 52983, by appiah4
And voila, one ATI Rage Fury MAXX restored.. But does it work? We'll find out soon enough.
Reply 28756 of 52983, by Vynix
The amount of *rage* that this card will bring you if broken will go way off the charts (... Get it?)
Reply 28757 of 52983, by appiah4
Maxximum Rage.. (No I haven't tried it yet, don't have a build with an AGP slot around and won't have one for a few weeks..)
Reply 28758 of 52983, by Thermalwrong
Ooh, good luck - I was going to add that there is superglue / epoxy debonder that disolves the glue, but maybe that's just kerosene? I have a 20 year old bottle of it that was used to clear the epoxy off of my ATi Radeon DDR 64MB. I have a recollection of clearing off that white thermal glue with that stuff, and about the same way you did overall.
Intel486dx33 wrote:
I built my Terratec Audio studio PC awhile back. That EWS-88MT is missing the rear connector on the bay drive. But I made a diag […]
That case setup looks amazing 😀 I really like the choice of DVD drive as well, I was tempted to pick one of those up when I first saw it, very fitting for that case design. Do each of those cards work together without fighting for resources?
Today, I received a completely broken motherboard! The one motherboard I've been seeking out for a few months because I have a special adapter, for this very specific motherboard. That the seller chose to package in just bubblewrap, going across the oceans, hundreds of miles, just arrive looking like this. Doesn't work at all...
833.5 KiB
654.94 KiB
edit: somehow within 5 minutes of contacting the seller about this, I found the same motherboard, weird that I couldn't find it before? (though this one is more expensive, but down the rabbit hole I go)
Reply 28759 of 52983, by Windows9566
Thermalwrong wrote:
Ooh, good luck - I was going to add that there is superglue / epoxy debonder that disolves the glue, but maybe that's just keros […]
I had the same issue with a Intel Advanced/ATX (Thor) 430FX board, the seller only shipped it in a thin layer of bubblewrap and it was dead as a doornail, no posts, nothing. got a refund for shipping damage. I later got another one which works fine, even was packaged much better, with more layers of bubblewrap and some newspaper outside of it, even has a MR BIOS installed on it.
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
