Reply 11960 of 31844, by dionb
- l33t++
wrote:wrote:You could always use a cheap Chinese mini wifi bridge instead; no drivers no headache.
This is what I do for my desktops (house not wired for Ethernet 😢 ) and for DOS/Win3.1/Win95 laptops... but for Windows 98SE I like a more integrated experience if possible. Plus those Chinese bridges are very flaky to configure.
I'd just use a regular router set to client bridge mode. Something decent from the 802.11n generation is more than sufficient in term of performance (if it supports 5GHz), available for less 2nd hand if you don't already have one knocking around somewhere, and far more reliable than bottom-scraping new stuff, particularly if it supports OpenWRT and you install that over whatever proprietary OS it had - usually just a skin over an outdated OpenWRT anyway.
