First post, by Lazar81
Hello,
I don't know what to do anymore. I installed Windows 98 se now 20 times or so... Everytime I install the Chipset driver I got freezes after booting.
I am using a Chaintech 6via5t. As hdd I installed a SSD with a sata to ide adapter.
Everything is running ok - but as soon as I have installed the Chipset driver it crashes directly after booting.
The Chipset driver package is the Hyperion 4in1 435.
Ryzen 5 2600X - ASUS ROG STRIX X470-F Gaming - 32GB RAM - Nvidia GeForce GTX 1080 Ti
Reply 2 of 5, by Lazar81
Well ... Looks like I have found the problem. I think the adapter does not support dma mode for hard drive. Pity
Reply 3 of 5, by Lazar81
So here we are again. And I solved the Problem. It was the adapter that prevented the usage of dma mode. I tried a bunch of other adapters and found the model from startech "40 pin ide to sata converter" working very well with SSD drive. And dma Mode is running out of the box.
Reply 4 of 5, by weldum
these adapters are hit and miss
still, via drivers aren't very good either, i had a lot of problems with post-2000 via chipsets and 9x/ME
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 5 of 5, by Lazar81
After all there were no driver issues. I installed the Hyperion 4in1 4.35 (it seems to be the most stable with win9x and my hardware) and everything runs fine. It was obviously the adapter, that couldn't manage the dma. So looks like I have a hit now. I used startech products before. I find them sometimes a little bit expensive - as it is now for this adapter - but I never had any problems with startech. Although I read, that this new adapter wouldn't support dma for very old drives. Whatever that means...
