First post, by amadeus777999
- Oldbie
After a long hiatus I started said board and there was an error message which said something about the Bios being corrupt at startup.
The PC is running fine in DOS but in windows I can't install any PCI(-gfx) cards because it always throws a resource conflict.
I didn't change anything in the configuration(gfx card or jumper settings) when first encountering the error so I strongly assume that the root cause may lie with the BIOS having been corrupted...
...Ideas and bios files welcome.
