First post, by Ozzuneoj
- l33t
I'm going to try to keep this short and to the point. I have a growing collection of wavetable sound cards and MIDI modules, but it is surprisingly difficult to find a good explanation of how some of these compare on a technical level. I'll list each type of synth, and a basic question regarding it. Any thoughts on any of these subjects are welcome. And yes, I've seen this thread. 😀
Software Synthesizers - These work on most sound cards (generally only in Windows) and many times allow for custom sound fonts to be used. These days it's also possible to use a second PC as a host for the soft synth while piping in MIDI from a DOS system, thereby turning a PC into a "software" sound module. With gigantic (sometimes in the GB size range), super high quality sound fonts and tons of processing power, how are these not "the best" at everything? It seems like someone could easily use sound fonts that match the standard Roland sounds from years ago, possibly with higher fidelity and cleaner outputs from a modern sound card. And yet, this seems like a fairly unpopular option.
EMU8000, EMU10K1 type chips - I know that DOS compatibility is limited since the synth isn't hard wired to the MPU401 interface, but under Windows what makes an AWE64 Gold! with a 4MB ROM (or even an AWE32 with a 28MB font loaded in RAM) merely "acceptable" to most retro enthusiasts, compared to a GM daughterboard with a good 4MB ROM that people will spend hundreds of dollars on? Is there any technical\audible difference between the built in sample ROM on a AWE32\AWE64 and a sound font loaded in RAM?
YMF-724/744 XG (might as well lump in any others that are only MPU401 compatible in Windows) - With the YMF-724, this was a fairly cheap, simple, budget oriented card, and yet under Windows it can have very impressive GM\XG playback... what do you actually lose with something like this versus an extremely expensive Yamaha XG external module from the same era with several times as many internal components?
GM\GS\XG Sound Modules - Roland, Yamaha, etc... generally have a built in set of samples that cannot be changed and are quite complex and expensive devices. With so much dedicated hardware inside these things, what does it all do that can't be done with a sound card from the same era that had a fraction of the cost and complexity? Is it related to the quality of the effects rather than the size\quality of the samples used? Is there any audible difference between one of these and the matching daughterboard\card that has the same specs (like the Roland SCC-1)?
Sound cards\daughterboards with hardware wavetable synth and a built in ROM - From my understanding these are the closest to the functionality of the GM modules above since they are usually compatible with any software that will send GM data to an MPU401 device. Compatibility makes them more desirable obviously, but if a soft synth or EMU8\10K were loaded with the same samples found in the ROM of one of these cards, what is it that makes them sound different? There are obviously differences between the many cards with hardware synth capabilities. What makes them sound different aside from the samples? Is it just reverb\chorus effects?
Sound cards with hardware waveteable synth and expandable *RAM* - Some cards (Guillemot Maxisound Game Theater 64, Turtle Beach Multisound Pinnacle etc.) are MPU401 GM compatible but also have RAM expansion slots. Presumably (I don't own either of these) you can use these without adding any samples to RAM, so they have a built in ROM, but what is the difference between using the samples from the built in ROM and loading one into the expansion RAM? Why bother having a ROM at all if the driver can simply load samples (possibly even higher quality) into RAM?
What I already know:
Obviously everyone will have their preference for which ones sound the best for certain tracks, and many tracks were made on well known modules so they are the most "accurate" on those devices (for example, the SC-55), and software compatibility is also a major factor in which one is ideal for given situation. My question as to how they compare is more "why are they so different" than "which one is better".
