First post, by CU_AMiGA
Hey guys,
I got a bit of a puzzler here. I recently rebuilt my system (upgraded the processor slightly), meaning i also had to reinstall everything, Win98se, drivers, everything. Now the problem i have encountered is for some unknown reason my Voodoo 2 doesn't seem to get picked up properly by anything that uses D3D. Its recognised fine under Directx diagnostics (and tested), and anything that uses Glide work no problem whatsoever. I have no idea what has caused this, i could've sworn it worked fine in the past. Anything that i had used to test D3D (ie VP 3 and GTA 2) have came back with an error message saying that a D3D supported device couldn't be found).
I have tried different Directx versions, different Voodoo2 drivers, i have even tried a different motherboard and different processors - the exact same results everytime! I am pretty much ready to give up on the Voodoo 2 and just buy a different less troublesome graphics card on ebay, but i thought i would ask here beforehand as a last ditch effort to see if i can get this going again. Anyone have any suggestions?! I am totally stumped here! 😖
