Chips & Technologies F64300 VLB vga question
First post, by stalk3r
I bought this video card recently, a Chips & Technologies F64300 Wingine DX, which, according to the manual, sports a video cache called XRAM:
The XRAM Accelerator Cache (patent pending) is a breakthrough in performance technology. By using one standard 256Kx4 Fast Page DRAM, a proprietary algorithm implemented in the 64300 significantly increases graphics system performance.The result is performance never before achieved in standard DRAM-based graphics architectures. For added flexibility, the XRAM Accelerator Cache is optional.
Sounds exciting isn't it 😀 The empty sockets are there above the video RAM, so I assume I could simply enable it by throwing regular DRAM chips on them?
Reply 1 of 31, by jcarvalho
Yes, we can assume that. Just pull a pair from s3trio PCI and give a try
Reply 2 of 31, by stalk3r
You mean the brownish socket on a S3Trio? I think the cache ram goes to the small black DIP socket on the top the card, does a S3 Trio have that as well?
Reply 3 of 31, by keropi
yes , the soj sockets are for an extra 1mb of vram... I would also guess that the "cache" goes to the dip sockets on top
Reply 5 of 31, by kixs
386_junkie wrote:
Be sure first which memory you need... VRAM or DRAM. Using the incorrect RAM type can damage the card and memory.
It says:
So any chip from an older VGA card would be fine. But I'm not sure why it says "one". There are clearly two DIP sockets.
I have this card but haven't had the time to test it...
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 6 of 31, by rasz_pl
You can safely assume its marketing wank, PC Mag 6 Dec 1994 description sounds like some kind of deeper fifo to hide rasterization delays from host (outputting framebuffer to screen blocks main host from writing to video memory). You would have to find actual alleged patent application to know more.
still at $4 with free shipping for two MB81C4256 its something fun to try, you can test if its working by:
INT 10 - Chips & Technologies '64300' BIOS - GET XRAM INFORMATION
AX = 5F06h
Return: AL = 5Fh if function supported
AH = status
00h unsuccessful
01h successful
BL = XRAM presence (00h no XRAM, 01h present)
SeeAlso: AX=5F05h,AX=5F08h
of course I would buz out all the pins to sanity check if thats really where ram is supposed to go.
Reply 7 of 31, by stalk3r
It is per memory bank, one for 1MB, two for 2MB
Reply 8 of 31, by stalk3r
Regarding its speed, should it match the 70ns video RAM on board?
rasz_pl wrote:
of course I would buz out all the pins to sanity check if thats really where ram is supposed to go. […]
AX = 5F06h
AH = status
00h unsuccessful
01h successful
This is useful, thanks. I will try it.
Reply 9 of 31, by appiah4
I also happen to own a similar card:
I always thought the empty sockets were for 1MB to 2MB upgrade? U guess the U7A and U14 are for the XRAM upgrade but on my card they are not socketed or populated..
Reply 10 of 31, by stalk3r
appiah4 wrote:
I also happen to own a similar card: […]
They are for the 2MB upgrade. The two extra DIP sockets are seemingly missing from your card, you can see their places on the top "MT4C4256"
Reply 11 of 31, by appiah4
Do you know how this card compares to CL-GD542X cards? I have to pick between this and a 2MB CL-GD5428 for my 486 build 😀 Is the 2MB upgrade on either card of any use for a 486 PC?
Reply 12 of 31, by stalk3r
I have no idea how does it perform, I have not had the chance to test it so far, furthermore this is my first VLB card ever 😀 By the way, for DOS-only usage I don't think there is a benefit of having a 2MB card. Maybe for some later SVGA games for which a 486 might be too slow anyway.
EDIT: there is a test of all mainstream VLB cards in PC Mag issue Dec 1994, this card goes by the name Boca Voyager:
https://books.google.ch/books?id=PITtFPwTaWwC … epage&q&f=false
Reply 14 of 31, by stalk3r
rasz_pl wrote:
You can safely assume its marketing wank, PC Mag 6 Dec 1994 description sounds like some kind of deeper fifo to hide rasterizati […]
AX = 5F06h
AH = status
00h unsuccessful
01h successful
I've just had the time to check this; adding or removing "XRAM" chips does not change a thing in terms of dos performance (it does change registers AH, AL so I am pretty sure the feature was enabled). It was indeed a marketing wank 😀 The card is bloody fast though in DOS regardless the presence of XRAM chips, got pretty much the same if not higher scores than high-end VLB cards.
Reply 15 of 31, by kixs
kixs wrote:
It says: […]
It says:
Tested my card a few weeks ago. It performs good in DOS and Windows. Extra cache chips only increase performance in Windows adding around 25% boost.
Reply 16 of 31, by stalk3r
What I like about it is that it gives pretty good image on modern LCDs, as opposed to e.g. an S3 Trio VLB whose image is utterly crap. I guess it's related to the quality of DAC . But good to know the "XRAM" gives a boost in Windows.
Reply 17 of 31, by The Serpent Rider
BTW does anyone have dedicated win9x driver for this card?
Reply 18 of 31, by Eep386
I found one a while back to replace the bug-tastic one Microsoft shipped with Win95.
It seems to fix the random lockups on screen mode changes as well as the super-annoying Windows mouse cursor appearing over DOS applications.
The F64300 should detect as 'Chips & Technologies, Accelerator (New)' under this driver.
The attachment chips95.zip is no longer available
Reply 19 of 31, by Gona
stalk3r wrote on 2019-04-18, 08:46:
I have tested this "XRAM Accelerator Cache" thing by installing two standard DIP from an other videocards and run DOOM2 timedemo (with and without installed DIP chips) but the two results are the same...
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
