Dos 6.22 cute mouse help
First post, by Pizmo
Hello.
I'm trying to get cute mouse to work with my old laser 386 with a serial mouse, but I'm dumb and cant make it work. When cute mouse is enabled it automatically assigns the mouse to com #1, but my 9 pin rs232 connector is listed as com #3.
According to the cute mouse instructions command /s [c] is how your change com ports, but again I am dumb and do not understand what that means. Can someone explain this to me like you were explaining it to a small child so that i can understand it.
Thanks
Reply 2 of 5, by BushLin
I would assume it translates to the command for COM3 as:
[code]CTMOUSE.EXE /s3[/code]
You can add the irq to the end, without a space, if it doesn't work OR have it scan for serial before PS/2 using the /V switch instead
[code]CTMOUSE.EXE /V[/code]
Screw period correct; I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
Reply 3 of 5, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 4 of 5, by derSammler
Actually, it would translate to:
CTMOUSE.EXE /S C3
Reply 5 of 5, by BushLin
CTMOUSE.EXE /S C3
That's probably what I originally wrote but then I tried it out. I don't have a serial mouse to test but the error changed to something like 'device not found' when using the syntax I later edited; rather than complain about the switch not being valid.
