tomb raider crashing during save
Reply 20 of 46, by Glidos
The clickin isn't a problem in its own right. Unless you have a TFT monitor, you want 85Hz probably.
What sort of flicker?
Reply 21 of 46, by demione
thansk for the suggestion, I'll get to work on uninstalling VDMS and glidos.
Just so I know for reference, does glidos modify the tomb.exe file at all? or does glidos simple provide a wrapper that executeart of an unmodified tomb.exe?
another question -- what does tr1 need the cd for? anything besides a copy protection check and the music?
Reply 22 of 46, by DosFreak
GliDOS doesn't modify any of the games files, it acts as a Glide emulator intercepting the glide calls from the game and redirecting them to OpenGlide (Glide emulator).
IIRC, it just needs the CD for the CD audio.
Make your games work offline
Reply 23 of 46, by Glidos
Actually needs the CD for the game content aswell. One of the few games that installs very little onto the disc.
Reply 24 of 46, by JC
Difficult to describe flickers really, but it sort of looks as if the pixels are all re-aligning themselves in a horizontal band across the centre of the screen.
If I switch "Anti-Aliasing - application preference" off, then tick a box that says "temporal anti-aliasing" - I have a choice of 2X, 4X or 6X and it doesn't seem to matter which of these I choose - then the flicker is history!
A side effect of this though happens in the menu: instead of having a dimmed image of where you are in the game, everything except the top left hand quadrant is blacked out and what you see in the remaining quadrant is not dimmed.
None of this has offered the slightest relief to the "hang / save game" problem though.
Reply 25 of 46, by Glidos
Ah, it is an TFT. That sort of flicker is when the monitor is having trouble syncing.
Reply 26 of 46, by Glidos
There was a good chance that wouldn't help at all, because it really doesn't look to be the Glidos side of things. Its the DOS side. I may have asked this. Have you tried setting up TR to not use audio?
Reply 27 of 46, by JC
No - how do I do this? does it involve re-installing?
Reply 28 of 46, by Glidos
Run c:\tombraid\setup.exe
Or if that file doesn't exist, see if there is one called install.exe, and rename it to setup.exe and then run it.
Or copy the install.exe from your TR CD into that folder, and rename it to setup.exe, and then run it.
Reply 29 of 46, by JC
Bingo! This seems to be the source of the problem! Does this mean I won't be able to play the game with CD Sound? (The MP3 sounds are playing back just fine of course!)
Reply 30 of 46, by Glidos
Its not the CD audio that you are losing; its the digital audio (gun fire, footsteps etc). You could try reenabling it, but disabel MP3 sounds in Glidos. See if its a bad interaction.
Also may be worth looking to see if there are more up to date drivers for your sound card.
And maybe uninstall and reinstall VDMSound.
Reply 31 of 46, by demione
are you aware of any different retail versions of tomb raider containing different alternatives (or versions) of tomb.exe? if so, is there any way to check which "version" i have?
Reply 32 of 46, by Glidos
But you don't use that tomb.exe anyway. You use the voodoo version.
Reply 33 of 46, by demione
ah, well, you get my point. are any incongruities known to exist?
Reply 34 of 46, by Glidos
No I don't really get what you mean. There may be some version related problem if you sometimes use Glidos, and sometimes run without Glidos, using the original tomb.exe. Some people have run into problems with save games from one sessions not working in another.
Reply 35 of 46, by JC
I did what you suggested. Re-enabling the digital sounds and disabling the mp3 resulted in everything seeming to work fine, so the nasty interaction theory would seem to be right. I uninstalled and re-installed VDM Sound and I do have the most up to date driver for my sound card. Unfortunately, re-enabling all the audio has brought the problem back.
Reply 36 of 46, by IveAnAlienInsideMe
Recently installed TR1 with glidos and have been getting the similar crashes when saving.
It locks at the point when all the components go to the centre after you've saved, the PC isn't locked and glidos can be quitted using the right windows key (disabled the left on because it was also causing crashing / annoyance). the save game created is there but is called savegame.X and doesn't work.
I may be imagining it but noticed that it seems to happen a less if each time I save choose a new slot?
While my friends are enjoying taking the micky of me playing TR1 on a top system, (FX60 7800gtx sli), I'm enjoying the nostalgia trip while wait for some decent new titles to arrive. First time around I was blown away by Tr1 (over previous software rendering). It was with an Orchid Righteous 3D Voodoo1 & pentium 166 mmx, (top end in it's day). Also wanted to say thanks to the Glidos Creator for his dedication to Glidos giving us the ability to run TR1 in 1600x1200. So TR1 is old and graphically simple in many ways, but you soon forget that and realise how great the game was / is. Don't let the crashing put you off just save more often, and if you have to do a section again it wont be a lot..
Reply 37 of 46, by Glidos
Are you using the Audio packs. JC was seeing a similar problem, and that seems to be an interaction between TR and Glidos's playing of mp3 tracks.
Reply 38 of 46, by cluelessnewbie
Hi everyone. Sorry to dig up an old thread but I'm getting the same exact kind of random crashing during saves. Disabling digital audio from the setup menu is the only fix that has worked for me. I've tried disabling mp3 playback in Glidos (I downloaded the audio pack previously) but that hasn't had any effect. My sound card is an X-Fi Elite pro, an updated driver should be coming out soon... I'll report back after I can try it out.
Reply 39 of 46, by Glidos
You are using VDMSound, yes?
