First post, by AlessandroB
Hi, i need to know:
-A software like win32 disk imager that work on a Win98 System (i wanto to use it on a PentiumII notebook to make images of CF used in other retro PC)
-If memtest86 work on floppy(my 486 not boot from a cd like hiren'2 boot CD utility), if yes how to download/create it. I need to check my 72 pin simm on my 486.
Tnks a lot.
Reply 2 of 6, by appiah4
An old version of Norton Ghost would probably do the trick for you.
Reply 3 of 6, by Caluser2000
AlessandroB wrote:
Hi, i need to know: […]
Hi, i need to know:
Tnks a lot.
Go get the PLOP boot loader. It allows you to boot from cd on your 486.
Reply 4 of 6, by AlessandroB
ok Floppy with Memtest86+ v2.00 make and perfect working
Reply 5 of 6, by ShovelKnight
There are several high quality DOS programs for copying and imaging floppy disks, take your pick: https://www.bttr-software.de/freesoft/disk2.htm (All these applications were free from the beginning or were re-released as freeware when DOS gave way to WinNT-based systems.)
I remember using HD-Copy back in late 90s.
Edit: sorry, I didn't realise you wanted software for HDD imaging. Try Partition Saving (it's freeware as well): http://www.partition-saving.com/
Reply 6 of 6, by AlessandroB
Very good, i will try tnks.
