Tandy 3 Voice Sound - SN76489 ISA Soundcard Project
Reply 181 of 484, by carlostex
matze79 wrote:
New Driver for Port Redirection without need of QEMM386 or EMM386 is in development.
How about decoding another port on the card? Port B0 or port E0 are good candidates, this will make patching games a lot easier.
Reply 182 of 484, by matze79
Maybe..
biggest issue are still the bios check of the tandy games 😳
Had time to retest all changes on real pcb.
accidently dropped some solder on one of the card fingers 😁
Reply 184 of 484, by DosWorld
I'll bay one, when it will done!
PS: I am software developer and need this card for development new ( 😊 ) software, so bios checks is not a problem.
CPU: Amd K6/450, RAM: 256M, VIDEO: S3Trio V+, SOUND: EWS64XXL/64M
CPU: iP/100, RAM: 16M, VIDEO: S3Trio V+, SOUND: SB AWE32
IBM Aptiva, CPU i486DX/80, RAM: 96M
Compaq Contura 4/25 2820D, CPU: i486SX/25, RAM: 4M, VGA.
HP 200LX/2M
Reply 185 of 484, by matze79
Almost ready now.
Just need some time to drill my bracklets soon 😀
I also noticed someone on ebay sales tandy pcbs but they are the old jj_pearce design, no muting, and pc-speaker MixIn can shortcircuit mainboard.
Reply 186 of 484, by keropi
I need one of these new ones matze79 😁
tbh I have not tried or patched the older version yet 😵 - it will be kept as-is for archival reasons along with the rest of alpha/beta stuff I have 😊
Reply 188 of 484, by DosWorld
Cool! Can't wait! 😊
HP 200LX/2M
Reply 189 of 484, by matze79
Adress Encoder is expanded to support 0E0 and also 2E0 for easier Patching 😀
if you have existing card / lo-tech Card and want to use 0E0 just connect Pin 16 of 74HC688 to VCC. Or for normal 0C0 to GND.
But i see no benefit, games running on 0C0 are always running on my 386/486 without Problems
and on my Pentium 3 i can not access low adress ranges at all, only 1E0 and 2C0 works here.
And for DMA issues ? i did not encountered one yet but i also did not many heavy testings with SB Cards installed.
I use it mostly in XT Systems and my Testing 486 😀
Reply 190 of 484, by dreamblaster
TNDY card arrived today, it looks really great, matze79, thank you !
The attachment DSCN4617.JPG is no longer available
Thanks for your support !
Reply 191 of 484, by matze79
Next one follows soon 😀
Now with your Pots on it and metal bracklet.
Reply 192 of 484, by matze79
Driver is making progress.. LPT Device Support is in the works 😀
(Screenshots with dosbox)
The attachment dosbox_007.png is no longer available
The attachment dosbox_008.png is no longer available
Reply 193 of 484, by Tiido
"periodic noise" is not the right term to use, it actually is a 6.666% duty cycle square wave (and 6.25% on SEGA VDP PSG). LFSR is operated without feedback so one single bit circles through 15 stages (16 on VDP) the register is long.
Reply 194 of 484, by matze79
The attachment dreambuster.jpg is no longer available
Reply 195 of 484, by root42
Nice. I still haven’t gotten around to order components. Will have to do that for the tndy and covox.
YouTube and Bonus
Reply 196 of 484, by matze79
Yes, will start assemble in septemper.. maybe i can order components for you also.
hopefully i can solder them then.
still suffering from tendovaginitis or similar sickness.. no idea currently, doctors sucks and it takes ages to get to the right expert.
Reply 197 of 484, by matze79
Tested and working 😀 now installed inside my NEC V20 System with PC-Speaker Passtrough.
Reply 199 of 484, by matze79
Knob added 😀
The attachment volumeknob.jpg is no longer available
Thanks, and works well.
