First post, by Violett'Blossom
Windows detects my Mitsubishi Diamond Pro 2070SB as a Generic PnP monitor(I tried looking for drivers in windows list, and havent found anything) and I can't select anything higher than 1024x768 even through the monitor can output 2k res.
Retro gaming : Compaq Armada E500
Portable : MacBook Air 2012
Hackingtosh : I5 6500 8GB DDR4 RX480 8GB
Reply 2 of 16, by Violett'Blossom
Failed to import file...
Reply 3 of 16, by Violett'Blossom
duga3 wrote:
1 - see attachment for official 2070SB driver
2 - download CRU from https://www.monitortests.com/forum/Thread-Cus … ion-Utility-CRU to add custom (higher/faster) resolution modes by overriding the monitor EDID.
Any other ideas ? 😊
Reply 4 of 16, by duga3
I would think it works like this:
- unzip the EXE into some folder
- in control panel find your monitor and click update driver or something
- then click select driver or something
- then click have disk
- then select the folder from the unpacked EXE
have you tried it like that?
What is your GPU by the way?
98/XP multi-boot system with P55 chipset (build log)
Screenshots
10Hz FM
Reply 5 of 16, by Doornkaat
How is your monitor connected? I'm not that firm on Win10 but can't you create/force custom resolutions and refresh rates in the GPU driver utility?
Also if you are somewhat of an advanced user this might help you override the EDID manually:
https://docs.microsoft.com/en-us/windows-hard … g-monitor-edids
Reply 6 of 16, by duga3
The GPU driver method should be used only as a last resort though. Modifying EDID (somehow, for example with CRU) is the most native/compatible way.
Thanks for the link, I might need to try that method for something else I am having issues with. Here is also an useful app to go with your link: https://www.entechtaiwan.com/util/moninfo.shtm
Screenshots
10Hz FM
Reply 7 of 16, by Violett'Blossom
duga3 wrote:
I would think it works like this: […]
I have tried like that, it errors out. Gpu is RX 480 8Gb Iam using adapter from display port to vga which has 300Mhz Pixel Clock
Reply 8 of 16, by Violett'Blossom
I have tried in AMD driver, it doesn't work 😢
Reply 9 of 16, by jmarsh
It will be a limitation of the adapter you are using, overriding the edid won't enable it to handle higher resolutions.
Reply 10 of 16, by duga3
Download that moninfo utility I linked above and copy-paste all of the reported "Asset Information" for your monitor (which should be already pre-selected in "Display IDs" column) here.
It would be great to know the exact error message you get when installing that INF driver setup file.
What exact adapter do you have?
Are you using BNC or regular VGA cable for this? If BNC, try VGA because BNC is not wired for EDID transfer.
Screenshots
10Hz FM
Reply 11 of 16, by Violett'Blossom
duga3 wrote:
Download that moninfo utility I linked above and copy-paste all of the reported "Asset Information" for your monitor (which shou […]
I am using Axagon DP to VGA adapter with shielded VGA cable.
When installing inf it told me that They cannot add the inf because it might be for 32bit version only, also the inf that i got from the moninfo Iam unable to use since it's not digitally signed...
Monitor
Model name............... DPro 2070SB
Manufacturer............. Mitsubishi
Plug and Play ID......... MEL4632
Serial number............ 47005512YB-5512
Manufacture date......... 2004, ISO week 28
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 400 x 300 mm (19,7 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... 1 (CEA/CTA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,627 - Ry 0,341
Green chromaticity....... Gx 0,292 - Gy 0,605
Blue chromaticity........ Bx 0,149 - By 0,072
White point (default).... Wx 0,283 - Wy 0,297
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-140kHz
Vertical scan range...... 50-160Hz
Video bandwidth.......... 420MHz
CVT standard............. Not supported
GTF standard............. Supported
Preferred timing......... Yes
Native/preferred timing.. 1600x1200p at 85Hz (4:3)
Modeline............... "1600x1200" 229,500 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
720 x 400p at 88Hz - IBM XGA2
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
640 x 480p at 85Hz - VESA STD
800 x 600p at 85Hz - VESA STD
1024 x 768p at 85Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
1280 x 1024p at 85Hz - VESA STD
1600 x 1200p at 75Hz - VESA STD
1920 x 1440p at 85Hz - VESA STD
2048 x 1536p at 85Hz - VESA STD
EIA/CEA/CTA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Not supported
Native formats........... 1
Detailed timing #1....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 2.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 225MHz
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 480p at 60Hz - EDTV (4:3, 8:9)
NB: NTSC refresh rate = (Hz*1000)/1001
CE video capability data
CE scan behavior......... Supports overscan and underscan
IT scan behavior......... Supports overscan and underscan
PT scan behavior......... Not supported
RGB quantization range... Not supported
YCC quantization range... Not supported
Report information
Date generated........... 27.08.2019
Software revision........ 2.91.0.1043
Data source.............. Real-time 0x0011
Operating system......... 10.0.18362.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,34,AC,32,46,88,15,00,00,1C,0E,01,03,80,28,1E,78,EB,9C,68,A0,57,4A,9B,26,
12,48,4C,FF,EF,80,31,59,45,59,61,59,71,4F,81,99,A9,4F,D1,59,E1,59,A6,59,40,30,62,B0,32,40,40,C0,
13,00,8C,29,11,00,00,1E,00,00,00,FD,00,32,A0,1E,8C,2A,00,0A,20,20,20,20,20,20,00,00,00,FC,00,44,
50,72,6F,20,32,30,37,30,53,42,0A,20,00,00,00,FF,00,34,37,30,30,35,35,31,32,59,42,0A,20,20,01,9B,
02,03,1B,61,23,09,07,07,83,01,00,00,67,03,0C,00,20,00,80,2D,43,90,84,02,E2,00,0F,8C,0A,D0,8A,20,
E0,2D,10,10,3E,96,00,A0,5A,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,29
Reply 12 of 16, by Violett'Blossom
The chip that handles DAC can do 270Mhz which is 1600x1200@95Hz at minimum.
Reply 13 of 16, by duga3
<- that is the important line from your report. 420MHz is great and plenty - but will be bottlenecked by the DP-VGA adapter (you have said it has a 270MHz limit).
I have modified the original INF file to support 64-bit systems now, you will find it attached. This makes the driver "unsigned" so you will need to disable the signature enforcement during the driver installation. Instructions are below:
#1:
Run this command in elevated "cmd" with Administrator rights to ALLOW installation of unsigned drivers:
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS & bcdedit /set testsigning on
#2:
RESTART PC
#3:
INSTALL THE DRIVER via control panel using the "HAVE DISK" method
#4:
Run this command in elevated "cmd" with Administrator rights to BLOCK installation of unsigned drivers (=back to the original state):
bcdedit /set loadoptions DENABLE_INTEGRITY_CHECKS & bcdedit /set testsigning off
#5:
RESTART PC
Note that I have no good way of testing it on my end so let me know if there will be an issue with installing it 🤣
I believe Windows has built-in drivers for some 17" Mitsubushi CRTs and the like but not for this specific later model.
If the installation goes well, try what you wanted to try regarding higher resolutions and if it still wont work then let me know what exactly you were trying (how, where, etc).
Screenshots
10Hz FM
Reply 14 of 16, by Violett'Blossom
Wow, It have worked really well, I can now do 160Hz now, even tho I still can't select more resolutions, gotta get new adapter 😀
Reply 16 of 16, by dr_st
The monitor shouldn't matter, the GPU driver should. Things may have changed in Win10, I don't know. It's possible that the DP-->VGA adapter is screwing things somehow.
