First post, by AlessandroB
Can you please tell me a correct thread that teach me how to setup a multiboot in a computer that have already installed win98SE without reinstall it but just ADD WinXP? I have seen a moltitude of threads but never find what i need.
Tnks
Reply 2 of 19, by WinSxS
Or install on second HDD (don't forget unplug first HDD to installation), imo better option.
Otherwise you got Win98 on partition C, WinXP on D, i think you don't want it 😀
Bad english? Don't mind, i'm still learning
Main PC: CLICK
Retro PC: CLICK
Reply 3 of 19, by Wolfus
Why not, if I may ask?
Reply 4 of 19, by AlessandroB
thanks to all, first of all is a notebook, so only one drive. wich tool i use to partition the drive where win98se is already installed? and wich kind of partition must be the second one? (xp partition).
Reply 5 of 19, by Srandista
Well, I don't know, if I have a good answer for you, hut here we go.
I was able to do your desired dual boot setup, but only if I created Win 98 partition with its own FDISK utility and didn't use any 3rd party partition tools whatsoever (so you'll probably have to go through all of that partition stuff once again from beginning). You can read about it in following topic, with guide from other Vogons member.
[SOLVED] Win 98 / XP Dual Boot Problems
Reply 6 of 19, by WinSxS
First one - few applications requires OS installed on first partition (i mean C), second one - possible just for me - more comfortable, when I have OS on C.
So in my view you should install OSes on two hard disks, then pick in BIOS (ie. Hard Disk Priority) which has to be booting device.
Main PC: CLICK
Retro PC: CLICK
Reply 8 of 19, by Srandista
AlessandroB wrote:
i can't is a notebook.
Again, go through this topic and then use included guide there.
Reply 9 of 19, by WinSxS
You have no choice... So install standardly, 98 on C, XP on D and pray to all apps works fine 😁
Main PC: CLICK
Retro PC: CLICK
Reply 10 of 19, by jaZz_KCS
Hiding primary partitions from another, only ever having the one with the desired OS active, ergo always having the booted Windows as drive C:, and doing all this with a few keystrokes in Smart Boot Manager is the way I would go.
Reply 11 of 19, by AlessandroB
smart boot manager will be ok, but , now that win98 in already on the drive... can you suggest the step to install xp? my old-pc capability are a little rusted... tnks
Reply 12 of 19, by jaZz_KCS
So you have Win98 already on a partition? or the full drive? If so are you able to "cut off"/create a new primary partition for XP? If so, do that, create a new primary for XP, which should automatically hide the Win98 primary, as there can only be one active primary in Microsoft land. Afterwards, install XP, this will undoubtedly overwrite your bootstrap and automatically always launch XP afterwards. To "correct this", install Smart Boot Manager afterwards (or a manager of your choice). This will make the bootmanager appear each bootup, and you can activate/deactivate the primary of your choice from then on.
Reply 13 of 19, by AlessandroB
Fantastic explanation, very clear. I have windows 98 in one partition, to create the partition for XP, do I have to use a live disk like UBCD or can I use software directly from windows98? tnks
Reply 14 of 19, by jaZz_KCS
I would use DOS based or Live discs to use software like gparted or PartitionMagic 4.0 for DOS and create another primary.
Reply 15 of 19, by AlessandroB
after an hour of attempts I was able to find a working software to partition the disk. I created two partitions, in the first one remained windows 98 (which was already installed), while in the second I left it unformatted. I then rebooted the machine with the windows xp disk and with that I formatted the partition left free (empty space). Now starting the computer he asks me which system I want to start with (I think he uses a boot manager integrated in windows xp) and everything works, only that windows xp is now in the partition with letter (E). Do I try to see if everything works without making changes?
Reply 16 of 19, by chinny22
If your happy with XP being on E:\ then I wouldn't worry.
I've been duel booting with Win98 on c:\ and XP on different letters for years without any problems.
Worst case XP can access Fat16 or Fat32 so if any crappy programs DO need to access c:\Windows, they still can (even if it isn't the correct windows)
But 99.9% of the time no one has any issues.
Reply 18 of 19, by Srandista
Which one?
