First post, by Durandal
Hey all, I recently bought one of those Advantech PCM-9375 single-board industrial computers and am trying to figure out how to connect a floppy drive to it. It has a few different connectors on it, but none of them are the standard 2 row 34-pin header for floppy drives.
http://advdownload.advantech.com/productfile/ … _Manual_ed2.pdf
This manual from Advantech's site implies that there's some kind of floppy module or cable that I need, but I can't find a single instance of such a thing online. Does anyone have any experience with one of these?
Thanks,
Durandal
Reply 2 of 7, by Durandal
imi wrote:
you could probably just get any PC/104 floppy controller maybe the mentioned floppy module is just that? […]
can't find any picture of it:
https://www.digikey.com/product-detail/en/adv … 580E-ND/5638943
I found that page too, but I can't tell if that's even what I need because there aren't any photos, datasheets, manuals, etc. for it online. Digikey is out of stock anyway and I can't find it anywhere else other than a shady site that appears to be based in China.
I also emailed Advantech yesterday and haven't received a reply yet.
Reply 3 of 7, by Warlord
Apparently the PC-104 port is both a floppy header and a printer header, and the module determines what it use.
Reply 5 of 7, by Durandal
imi wrote:
regular PC/104 is just ISA on a pin header
according to this: https://www.infinite-electronic.sk/datasheet/ … 75FZ2-J0A1E.pdf the part number listed above is most probably what you need.
So if PC/104 is just ISA with a different connector, another option would be to buy/make an ISA adapter for it and use a floppy controller card, right? I may go down that route if Advantech doesn't reply and I can't get my hands on the floppy module.
EDIT: this looks like it could be an option for my use-case.
https://arstech.com/install/ecom-prodshow/isapc104.html
I'm trying to make a tiny all-in-one portable/luggable PC for convenient and native copying/dumping of 3.5" floppies, since it's something I do often and don't have the space to setup a full PC tower. Inevitably I'll also end up using it for games 😜 I might try to design the case to fit a 5.25" floppy drive too, although that would increase the weight significantly. Maybe I'll mount an external connector or something.
Reply 6 of 7, by Thermalwrong
It does look like it requires the extra module, but why not try using a USB floppy? It looks like it's new enough to have native support for that, but I guess not as ideal because it's not a direct floppy controller.
Reply 7 of 7, by Durandal
I've always had bad experiences with USB floppy drives. They never work quite right for whatever reason, I'm sure somebody here knows why. And when it comes to attaching a 5.25" drive via USB I know that this exists:
http://shop.deviceside.com/prod/FC5025
But it doesn't say outright that it would be compatible with a drive capable of writing 360KB disks, it only lists the Teac FD-55GFR as being for sure compatible, which can't write 360KB.
