First post, by Furztherapeut
Hey guys, for some reason I can't figure out how to make Technomage work with DgVoodoo 2.61. Also tried v2.54, same problem. Everytime I launch the game it looks like this (original size):
I've used dgoodoo with tons of old games by now, so I know the procedure. The game will usually detect the DLLs once you put them there. In fact the game's separate graphics setup lists "dgVoodoo DirectX Wrapper", which I've selected. I put the D3D8.dll, D3DImm.dll, DDraw.dll and dgVoodooCpl.exe in the directory, which I think are all the files I need. The game just seems to ignore the DLLs I put there, which is strange cause the graphics setup exe sees them.
Reply 1 of 3, by Dege
I myself didn't yet test this game.
What does the debug version of dgVoodoo say? Is is detected at all, according to the log?
Reply 2 of 3, by ZellSF
It says nothing. It's one of these titles:
Re: Tech demos - general discussion
Reply 3 of 3, by Dege
Oh, I had the same guess...
But it's strange that the graphics setup app doesn't initialize DDraw through OLE.
@Furztherapeut
You must change all 'InProc32' entries in the Windows registry containing the path of ddraw.dll. It's safe, I usually do it for myself after each windows feature update - but it's a bit complicated. You need ProcessHacker + the TrustedInstaller plugin.
Or, try the game on Windows 7, it should work there. Win7 contains relative ddraw.dll paths in the registry, unlike Win8/10.
